car is perfect
a lot mods are nearly new
engine only done about 7000KMs after rebuild
well balanced mods GTR
Genuine kms
clear history
every 3000kms service, use best oil. eg: RP engine oil, Motul rbf 600 brake fluid, full syn fluid everywhere:)
selling reason: want a quiet sport car.
price: $85000 if you think its expensive please read mods list carefully
any inspection welcome:)
mods list:
Engine: (7000kms old engine)
1. JE pistons/rings
2. H beam PRECISION rods
3. ARP racing hard stud/bolt
4. ACL head gaskets
4. AcL racing bearing set
5. valve spring
6. nismo water pump
7. nismo oil pump
8. tomei camshafts in/ex
9. tomei cam gears
10. clear cam cover
11. Splitfire super direct ignition system
12. NGK spark plug
13. nismo baffle plate
14. tomei oil restrictors
15. oil catch can
16. ARC front plate
17. nismo radiator cap
18. nismo oil cap
cooling
1. trust oil cooler front
2. nismo intercooler
3. arc radiator 36mm
4. arc cooling panel
5. billion racing PS tank
6. samco radiator hose set
exhaust
1. hks dump pipe
2. hks front pipe
3. trust pe II drag 94mm catback (3000kms old)
4. high flow cat (3000kms old)
Electronics:
1. apexi avcr
2. apexi pfc
3. 2* z32 afms
4. trust oil pressure gauge (2000kms old)
5. trust fuel pressure gauge (2000kms old)
suction:
1. trust T517z kit 8cm
2. nismo piping kits
3. apexi power filter kit for z32
4. apexi carbon airbox
fuel system: (the whole fuel system less than 3000KMS except nismo intank fuel pump)
1. tomei fuel rail
2. 3L surge tank
3. 2* bosch 044 fuel pump
4. nismo intank fuel pump
5. 6* Power Enterprise 800cc injectors
6. sard fuel reg
7. 2* bosch fuel filter
9. all fitting
suspension & brake & drivetrain
1. alcon 6piston brake kits 365mm disc F (2000KMS old)
2. alcon 4piston brake kits 335mm disc R (2000kms old)
3. adr prove brated brake line (2000kms old)
4. DS2500 PADS all around (2000kms old)
5. DMS 50mm 2way coilover kits (1000kms old)
6. rays Progressiv ME 19*10.5 +12
7. 275 30 19 595SS (near new)
8. nismo big operating cylinder
9. nismo super coppermix twin plate clutch (7000kms old)
10. cusco 1.5 way LSD (front)
11. nismo short shift kit.
12. PILLOWBALL UPPER MOUNT (F&R) (1000kms old)
other
1. nismo clear side light
2. nismo front bar vent
3. nismo carbon look pillar
4. nismo side skirt and rear pads
5. DVD player
460HP 1.45bar 385hp 1.1bar very very safe tune, knock no more than 20 on PFC. this car still have a lot potential. want more power? just give some more boost.
some more i can't remember.
the suspension make some noise(the noise from the valve which is normal for DMS 50mm), if you don't like it i can give bilstein 14b coilover for free. the bilstein doesn't make any noise and very good condition.
PM me if interest.
Edited by Nosure
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
