i bought this car about 5 years ago as a stock r33 gts..young & dumb
since then put a r34 rb25neo in full rebuild, forged pistons..r34 gear box...its got the bits...young and dumb
basically i spent wayyyy to much on it and it has been sitting in my garage for 2 years now with only 2000 k on the new engine and gear box, micro tech computer ..engine and gearbox not even had a chance to be thrashed by any means
i was in a car accident 2.5 year ago and buggered my back.getting down into it is hard work (im 6ft6)so i dont do it..(accident not in this car) plus got young family and car is not suitable.
i dont want it.. it takes up garage space.....offer me somthing..
it does need a good clean up and tune due to sitting for so long
i just tried to upload pics but am semi computer illiterate..
car is in brisbane south
pls call on 3219 5196 ask for dale
or email [email protected] and ill get mrs to upload pics and send them to you or if anyone here can help me thatd be good thanks
i would like 8k to 10 k but i am very realistic and open to all offers..
sorry i cou;ldnt get pics up on here
thanks for your time
https://www.sau.com.au/forums/topic/308732-r33-for-sale/
  • 4 weeks later...
tets ur inbox must be full..postmaster keeps sendin back my email
sorry man dont know where i got it.. some place on moss st
heres a cut and paste of email i been tryin to send to enquiries
ill add im not tech savvy so i wont be able to tell u anything extremely mechenical about it
what i can say is its rebuilt 2 yrs ago with only 3000 or less driven oni it
forged pistons
larger turbo but i couldnt tell u the brand..
bov
screamer pipe ( illegal)
3in exhaust
2.5in pipe work to the intercooler/turbo pipework
large custom throttle body..
microtech computer
microtech computer link up unit to do in car tuning.. i dont know how to use it..
i think the mechanics just like to see me spend/waste money...
oil catch can
individual coil packs.. (apparently this is a good thing so the mechanic told me wanting me to spend more money)
and the rest ur welcome to come have a look at.. or i ccan take pics
there is work to be done to it ie windscreen wiper missing, front bar needs fixing and other little odds and ends and anything thatd need to be taken off to make it legal and a tune and a damn good cut and polish
when i was driving it, it was only an initial rich tune , tuned to only go to 6 thou so i couldnt thrash it if i wanted too, to run it in.. so id say its only just run in if that
im sellin cause i cant be bothered with it and other reasons i mentioned on the website.. i thought it would go to someone wanting good motor and box and parts..or turn it into a drift/track car. i contimplated that as opposed to losing it all together cause it is a goer.. but decided to cut my losses and forget it
i can tell u the engine/gearbox/microtech computer etc surpasses 10grand..i can tell u now i spent 3 times that plus cost of car when initially bought.. but that dont mean shit to you..
hasnt been turned over in 1.5 years..unregestered..as far as when it was on the road..it drove well/tight..dont know the suspension condition but i know its got bilsteins which it had when i bought it
when first rebuilt 375hp at the flywheel on dyno..never got retuned due to accident and lack of interest
definately a good tune and some tinkering and some time spent cleaning it up and she will be the goods
regards
https://www.sau.com.au/forums/topic/308732-r33-for-sale/#findComment-5149332
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
