Hey guys, basically im moving to tasmania in just over 2 weeks.
i have a modified R33 skyline.
but heres the tricky part, i dont have the transfer papers. ( in SA this isnt a problem)
now what im asking is, what process will i take if i decide to bring the car with me over to tasmania in getting it into tas rego
cheers
https://www.sau.com.au/forums/topic/309225-help-needed-moving-to-tasmania/
cheers
here we have little to no rules lol.
If its has, legal tyres, legalish tint a horn and working lights its pretty much good to go. obviously some places are picky-er but the's a few approved inspection stations that are not so fussy.
I agree with Mr. Untouchable. I have brought a few cars over from the mainland and the usual things that they look at are tyres and ride height and tint and a few other miniscule things. If there is nothing majorly illegal on it and it doesnt leak bucket loads of fluids, usually you just have to bring it over the pits... I would go to RACT and if they dont like you Big Al's Garage in Longford will like you :)
Have fun on our roads, (meeting the legal speed limit of course)
so what if u (found) :P the recipt from when u brought it?
that and some photo id should do the trick,
think they will ask u to sign a stat/dec.
there is usualu ways n means arround these things
I don't know the previous owners name or address because he lives in nsw and the guy I bought it from doesn't either. It's a bit of a mess. Looks like it won't be coming with me to Tasmania
Car is registered to someone in nsw. A bloke from Adelaide bought it and then I bought it from him. Meanwhile he has misplaced the transfer papers. That sums it up in not much detail.
I'm hoping if I get a statdec from the previous owner from the Adelaide owner. That should prove my ownership and then registering in Tasmania should go without any hassles.
EDIT... the car did come with papers. but they were lost while i was arranging to meet him and pick them up.
find a recipt aka, lil bit of fraud maby? ;) lol its your car, i know i wouldnt sell my car for a mild technical hitch :)
i'm pretty sure you can sign a stat dec saying you(?) lost the transfer papers in transit :P , but alternatively , you only need the reciept of sale from the person you bought it off as far as i'm aware?
sorry to hijack this thread. but does anyone know a flexible workhop on the northwest coast who will give me a roadworthyfor the 34? it has a few mods and the guy i took my wrx to was a picky bugger, he did give me the peice of paper though, however im pretty sure he wont for the skyline.
cheers
Good luck with the 'flexible' bit.
What you have to realise is that if they get caught they loose thier licence to inspect cars and its friggen hard to get it back again.
As such, you may think they are being picky but they are only doing what is legally required of them.
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
