Hey all,
Did a bit of searching around but cant find a solid answer. So I thought I would ask in NSW as places in Vic are the only ones i can find
Bought a set of GTT injectors but cant find anywhere in the western sydney region to get some new pintle caps (the cap on the bottom end of the injector) and new o-rings for top and bottom..
I know of mobile injector cleaners that come out and clean them, replace all that but dont want to pay the callout fee of what would be more then 5 times the cost of new ones.
Nissan spare parts in penrith place looked at me like i was a retard.. Guy didnt seem to know wat to look for part no wise..
No luck google searching or ebaying either.
Any ideas where I can look?
Thanks,
David
https://www.sau.com.au/forums/topic/309256-injector-pintle-caps-and-o-rings/
you will have to order them though nissan ... if my memary serves me right they are the same as the r33s and the part number ...... i well get the par number for you tomorrow when i go out to the car
Hornsby Nissan quoted me $6 for the ring that sits in the manifold, $11 for the one connecting to the fuel rail, and $15 for the one in the injector. This was for RB20 injectors, and they have them in stock. I would say they might be the same for your injectors.
Hornsby Nissan - 1300 596 271
By the way, these guys aren't pelicans.
Thanks Jebud for the info,
I managed to get the o-rings.. $11 a pop is quite rediculous.
They didnt have the cap that sits on the bottom of the injector listed.. i guess ill have to use the ones off my old GT injectors if they fit something when i take them off..
thanks Andrew,
Tried doing a bit of searching around the net and 16636 72P00 seem to be for the r33 injectors and look a little different to mine (only 2 were broken off)..
Ill try and suss it out when i go back in to get the o-rings.
Thanks for the help guys
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
