Car: 2003 NM35 Stagea Autech Axis
KMS: 63,xxx kms
Mods: completely standard
Price: $31,000
Contact Details: PM or 0439 703 239
"2003 NM35 Nissan Stagea Autech Axis Edition, Silver with all genuine Autech bodykit and wheels. With its Champagne Leather interior, this is the executive wagon with performance to boot. Powered by a VQ25DET, 2.5 litre turbo V6, which shares a lot of common parts with the locally delivered 350Z, it performs incredibly well with 206kw of power and 407nm of torque. Even with this performance I still achieve real world fuel economy of 10.5L/100kms in the city cycle.
My example is completely factory stock, with the addition of a DVD player to keep the passengers entertained during longer journeys. It also comes with a cargo net which can be configured in multiple locations depending on luggage requirements, as well as an internal tonneau cover for added security. The split fold rear seats are able to be folded down very close to completely flat, and you can do this via the release found in the boot area.
Always serviced with premium synthetic oils, the vehicle has just been serviced including new brake pads / fluid / machined rotors + air filter and 4 brand new Dunlop tyres as well.
Creature comforts include DVD / MP3 player, Climate Control, Bose stereo system, 6 stack in dash CD player with tape and radio converter for Australian Frequency bands, Electric/ heated Front seats, Dual Airbags, Electric windows, mirrors, and the list goes on. This car is up for genuine sale as I am upgrading to a 4WD.
Overall this is an excellent high grade example of a rare vehicle, please call to arrange a viewing - you will be impressed"
IMG_8191.jpgIMG_8192.jpgIMG_8193.jpgIMG_8194.jpgIMG_8195.jpgIMG_8196.jpgIMG_8197.jpgIMG_8198.jpgIMG_8199.jpgIMG_8200.jpgIMG_8201.jpgIMG_8202.jpgIMG_8203.jpgIMG_8204.jpgIMG_8205.jpgIMG_8206.jpgIMG_8207.jpgIMG_8208.jpgIMG_8209.jpg[/img]
Cheers,
Andrew
Edited by Blue32
https://www.sau.com.au/forums/topic/309370-2003-m35-autech-axis-stagea/
I can't really tell from the photos... but does it have a sunroof??
No sunroof sorry - therefore I suppose this car is also 'bald bloke' and 'ginger' friendly (no sunburn through sunroof :) )
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
