For sale:
- New Serck 19 row oil cooler, (Serck are heavily used in motorsport)
- New Earls Remote filler kit for RB engines,
- New Braided line and Speedflow fittings to suit.
All parts are new and ready to be installed, Asking $680
Also for sale, New Bosch 040 Fuel Pump,
235 L/hour good for 500hp.
Asking $300
https://www.sau.com.au/forums/topic/30959-new-oil-cooler-fuel-pump/
No the Earls block and remote filler adaptors dont have interna check valves or thermostats like the R-type HKS kits.
They can be purchased separately and plumbed in line, also means an additional 4 x Speedflow fitting be bought which all adds to the cost.
Is the thermostat really necessary in Sydney/Aus where we dont see sub zero temps?
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
