hey guys,
had my skyline for a while now, its stock apart from front mount intercooler, split front dump pipe-full 3 inch exhaust, pod and boost controller. i have a power fc for it which i want to finally install and get tuned. i've allowed about 1000 bucks for tuning, (is this enough??) and im going to have a little bit of money left over, im thinking about getting a new fuel pump and a fuel pressure reg.
what do you guys think? would my extra money be better spent on different mods? and what sort of power output can i expect (roughly) with these mods? and also reccomend some tuners on the Coast/brisbane area, i'm thinking gavin wood-autotek.
any feedback would be greatly appreciated
cheers guys
Edited by bsd-gtst
https://www.sau.com.au/forums/topic/309642-r33-gtst-first-tune/
matt spry PITS
mark - GODZILLA MOTORsport..
easily get it installed and tuned for 1k and will have lots left over..
awesome thanks mate,yeah ive met Matt before he seemed pretty cool, heard he's a bit picky with the cars he tunes though??
Hey mate I have pretty much the same mods and i took my power fc to mark at godzilla. he fitted and tuned it for about 500 bucks from memory. He is great to deal with and really knows his shit :D
thanks mate, yeah ive heard nothing but good things about that shop eh, that sort of price would be great too, what sort of power figure did you end up with??
yeah my pfc was installed and tuned by mark.. was $545, didnt wanna post a figure as yours may require more tuning or he may have put his price up (mine was couple yrs ago).. but still 1k easily and you don't need to worry.. he knows his stuff and will do an excellent job
really? thats sort of price sounds great, think il have to give him a call for sure eh, thanks mate
hey guys,
cheers guys
Should be able to get a fuel pump and tune for that price but make sure you got decent coil packs and spark plugs. i had to replace mine which added another $800 for coils and spark plugs.
yeah true, the coils are standard and considering the age of the car id say they could do with replacing eh, thanks mate
you wont need an aftermarket fuel reg. the stock one will work fine for your power figures
really? well thats a good thing, maybe just a fuel pump and new coils then? ive been looking at a Walbro in-tank item? wat are these like anyone?? and most probably splitfire coils.
Mark will recommend tomei :cheers: I made about 180rwkw on a 40 odd degree day. He doesnt try to push every single ounce of power possible out of the engine which suited me fine. I asked for a safe tune and thats what I got.
I will definately going back after my next round of mods for another tune.
ok cool, yeah that sounds like exactly the sort of tune i am after, definately safe, considering the age of the car and the amount of standard parts :cool: think il have to give him a call for sure
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
