I have now for sale Coming off my black S2, all prices are excluding shipment, and are possibly negotiable :blush: as I have no "real" idea what thee are worth...
Bonnet - $350
quarters - $180 each
headlights height adjustable HID - $380 for both
high beams Blue hid - $ 250 for both
front bar with clear front indicators with yellow foggies $290
radiator support - $TBA
black grill - $180
also might have a radiator and auto trans cooler in a week or two
Pictures of whole front end up today sometime... when im not so hungover, pm or email [email protected]
Cheers, T
https://www.sau.com.au/forums/topic/310035-stag-pieces/
Also have :
from rear passenger door:
door trim - $50
Glass - $100
and all locks motors rails etc, let me know and we can sort out a price, all in perfect condition, just the door skin is damaged
https://www.sau.com.au/forums/topic/310035-stag-pieces/#findComment-5109961
:P:D waiting ;):geek:
:P
Sorry it took so long! am at work still :P here is some from my phone... can take more with real camera if need be tomorrow
Car is still together, but can take more pictures when my new front end arrives if you wish, all lights are in awesome condition.
https://www.sau.com.au/forums/topic/310035-stag-pieces/#findComment-5129040
Bonnet - $220
quarters - $95 each
headlights height adjustable HID - $290 for both
high beams Blue hid - $ 200 for both
front bar with clear front indicators with yellow foggies $180
radiator support - destroyed
black grill - $100
also, 2 x autech badges $25 each
S1 auto trans cooler $30
S1 condenser $30
S1 radiator with shroud $30
https://www.sau.com.au/forums/topic/310035-stag-pieces/#findComment-5144139
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
