Performance Parts Clearance Rb26 Ross Balancer, Rb26 Trust Sump, 720cc Sard Injectors Greddy Fuel Rail, 100mm Gtr Intercooler, L@@k$ie****************
Hi Guys,
Making a new thread with the left off parts from the sale
Used Performance Parts
RB26 Ross Balancer $450
Sard 720cc injectors with Greddy Fuel rail $915 (not seperating)
RB26 Sump with TRUST Sump extentsion welded $800
(Includes R34 GTR diff)
RB26 Clear Cam timing cover (slighly yellow) $60
Venolia Pistons RB25 Good condition (needs new rings) $400
6x Stock Rb26 rods $150
Brand NEW
RB26 Clear Cam timing cover $100
Genuine RB26 Nissan Gasket Kit (the one with a billion pieces) $300
100mm FMIC to suit GTR $300
R33 GTST stock parts
2x Dump pipe $10 each
Front pipe $10
2x Exhaust manifold $40 each
Intake manifold (corrosion on radiator hose pipe) $10
Damaged Thermo Free
Power Steering bottle $10
SMIC with piping $40
Washer bottle $10
Radiator overflow bottle $10
R33 front pair of suspension (pit use) $20
Pair of indicator lights (clear, front not side) $20
TurboSmart BOV Type 2 $80
Tcc Tech BOV Type 3 $50
R32 GTR boost solenoid $50
6x Stock rb25 rods $100
RB30 head (SOHC) comes with intake and exhaust manifolds $100
PM me with any questions
Located in PERTH but can arrange postage
Hi Guys,
Brand NEW
Front pipe $10
Damaged Thermo Free
Washer bottle $10
Hi i can't PM as my post is less than 10.
i am interested on the Venolia piston but i need some information on the piston
eg 86mm/87mm?
compression?
how can i get the piston ring?
Size is 86mm (stock bore) and Compression Ratio is 9:1 (Standard)
Piston rings can be purchased from a shop down in Northbridge (cant think of the name atm)
or ordered off the net from import performance parts etc
Edited by R32 Driver
I take it that the Ross Balancer is the R32 version???
If so, would you post to the US, of course paid by the buyer?
And, is it the model posted here??? RB26DETT Ross Harmonic Balancer
If so, post or send pics and consider it sold.......DIBS!!!!
Set of Work Emotions for sale to suit R33 GTST
5x114.3 18" Colour Bronze
Offset is +32 front +38 rear
8.5 inch front with 215 Toyo Proxy rubber
9.5 inch rear with 275 Toyo Proxy rubber
$2200
2x Toyo Proxy 18x35x275
$500 (retails $500 each)
20x Trust Wheel nuts (Bronze) Very light weight compared to stock nuts
$200
or All of it for $2500 Firm
No rim rash on any of the wheels, top nick with blue valve caps!
Will put up some photos soon
sorry if this is a dumb question but
can injectors/fuel rail be used on a RB25 neo motor? or generally can RB26 parts be used on RB25 or are they too different?
Honestly im unsure so its prolly best to ask on the Forced Induction threads
It will fit if you have a Greddy plenum (unsure about stock intake)
    • A quick google, and some E39 users have found pulling my sensor out/apart and cleaning it alleviates their issue. Then get the oil warning to go off, and once it is off (from the sensor saying it was unhappy) some find they can just unplug it and it is happy to just keep going now. Maybe give it a crack? If you can actually pull the sensor apart, hit it with some electrical contact cleaner.
    • Yep. In the E39 it's slightly different than the others. Honestly I'd just leave it but every time I drive the car it tells me oil is low and that just makes me check the dipstick. It is a BMW Afterall and it tries to expel it's own oil regularly.  Thankfully it's not like my E90 that has no dipstick at all so you just gotta trust it.
    • Was that also a typo? $350?! Just typing "BMW oil level sensor" and prices start out a lot more sanely than $350. I'm guessing it's a sensor used in one low volume model only or something?
    • They kept the product number the same, so we "didn't pick it up when packing your order". If you packed the order, you clearly saw the box wasn't Hella...
    • Actually, the equivalent skyline part is both cheaper and simpler, maybe you should come back from the dark side?
