Hi,
I am selling a R33 S2 explosion style front bar (uses original S2 lights) trial fitted only and ready to paint, puchased from JSAI in Sydney:
http://jsai.com.au/index.php?page=shop.pro...t&Itemid=29
Asking- $260 ono
Preffer local pickup (Sydney) as frieght can be expensive (around $300), if interested contact Chris on 0402 413 207
Thanks
https://www.sau.com.au/forums/topic/310149-r33-s2-explosion-style-front-bar/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
