Earlier today, the fat PS3's crashed "millennium bug" style.
The known issues are:
- Clock/Date reset to 1/1/2000
- No access to PSN
- Games with trophy support may/will not work
- Games purchased through PSN may/will not work
- Dynamic and some other themes are listed as "corrupted data"
The slim PS3's did not get affected; only the fat PS3's. Sony have yet to come up with a fix for the problem but have addressed it. It was rumoured that someone hacked PSN and introduced a trojan but that has since been denied by Sony.
Unfortunately, no COD for a while :down:
  • Replies 41
Yer was just about to post this. Got home onto my PS3, insert COD-MW2 cd and right as i was about to hit resume game, i get this error:
Registration of Trophy Information could not be completed - (8001050F)
I'm thinking f**k, which mongrel was f**king about with my ps3. Format the system and restore all defulat settings, still no luck. Googled the error code at the end and found out it was a gobal problem.. pheww
Official announcement from Sony
Some consumers are experiencing a network connection failure when signing into PSN and may receive the error code 8001050F.
We are aware of this issue and it's currently under investigation however at this time there is no estimated time to fix. Please refrain from calling your local PlayStation call centre and keep watching this space for further updates...
Edited by Barbarian
PlayStation Network Status Update
Posted by Jeff Rubenstein // Social Media Manager
We’re aware that many of you are having difficulty connecting to the PlayStation Network this evening. Those of you with “slim” PS3s (the 120/250 GB models) appear to be unaffected.
Know that we have narrowed down the issue and have engineers working to restore service even as you read this. We apologize for any inconvenience this may cause you, and genuinely appreciate your patience while we work to resolve this.
Quote:
Well the gist is that the ARM SYSCON CPU that is used to power up the front panel of the ps3, that is responsible for doing things like sleep mode, eject, RTC etc. Is an old batch that sony picked up from the shelf like other manufacturers that has that calendar year bug regarding feburary 29th on certain periods. Causing the ps3 system clock and the real time clock to desync, messing up security measures like Digital Rights management software and sometimes games that relies on clocks for whatever reason. As well as signing up to the playstation network... This CPU is always on even when your PS3 isn't even plugged in.
This problem is also happening with various of test Ps3 models, particulary the ones that has the emotion engine cpu/gpu for ps2 dev.
This is the one of the same type of CPUs that is powering up mobile devices like zune and blackberries, they have been affected with this bug, so they done some software patches. A syscon update can also fix this problem
The Slims ps3s aren't affected because they use a newer up to date revision on the syscon cpu that fixes this bug.
A quick way to fix this is to remove the RTC battery for at least 5-10 min and plug it back in, you will see the date and time reset, and voila...
found this here
Yep, somewhat of a pandemic, lol, i hope that trophy data isn't lost for good, or im sure heads will roll...
Here is the official word from Sony atm
http://blog.us.playstation.com/2010/03/lat...network-status/
and both the European and US sony twitter accounts
http://twitter.com/PlayStationEU
http://twitter.com/SonyPlayStation
So we're being told to not even turn on the PS3 until the problems fixed...
damn and I was right in the middle of Uncharted 2...
Well chances are you wont be able to play it anyway due to the trophy sync error, i can't play any of my games due to this, but demos work fine
So i'm guessing the older games will work?
so no Dante's inferno, bioshock 2 or uncharted 2 for a few days...
F**K Pull your head in Sony!
all is well now, although if you were unlucky enough to try and play any games while the ps3 shit itself, pretty much the whole of the 1-3-2010 then you most likely lost a whole heap of trophy data *sucks*
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
    • Isn't there a PAR engineering gearset that has closer to stock ratios? And they claim they'll do whatever ratios you want.
