Oh my god another skyline owner from the mornington peninsula!! That makes two of us. Welcome to SAU!! Im from Mt Martha, where abouts exactly on the Pen. r u from?
Esplanade in Mt Martha is fun for a quick spin, around the cliffs. You might see me there, dodging the helicopter-mounted speed cameras. :rofl: What a joke.
I got my car serviced at ice from recommendations here and they were good. THey let me hang around and they showed me everything they were doing so now i can do basics like oil change etc. I dont think there is much closer to fston, UPI would be a similar distance.
https://www.sau.com.au/forums/topic/31109-new-to-vic/page/2/#findComment-640120
  • 4 weeks later...
whats the go with those helicoper mounted speed cameras?  Im from out hastings way
There are white lines spaced 400m apart or so and the police it in a helicopter and time how long it takes you to go 400m. If your under a certain time, they get a car down the road to pull you over.
They did it alot last year, especially over the easter long weekend. You can still see the lines on the Esplanade between mt martha and safety beach and on Mooruduc Rd between Mornington tyabb road and bentons rd.
What a waste of money, it probably costs them $4k an hour to keep a helicopter in the air.
https://www.sau.com.au/forums/topic/31109-new-to-vic/page/2/#findComment-677205
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
