Vehicle 1996 NISSAN 180SX
Price $16,500*
Interior Colour Black
Kilometres 83,000
Colour Custom Gold
Transmission 5 speed Manual
Body 2 door 4 seat HATCHBACK
Drive type Rear
Reg Expiry DEC-2010
Engine 4 cylinder Petrol Intercooled Turbo 2.0L (1998cc)
Brief Comments REAL Type-x Fresh 2PAK paint, tasteful Mods, 201rwkw 13psi, lady owner, OR $14500 no diff/coilovers
comments
we have had the car for 4year all mods have been done by us, the car is only used as a weekend car serviced every 2000kms only motul products used.
its a 96 type x, been well cared and serviced regularly. weekend car always garaged
reason forsale - needs funds to buy a newer car. no swaps or trades.
exterior/ interior mods:
- custom gold paint with metallic silver undercoat house of kolor clear (2PAK) , roof painted in glossy black with gold specs, 3months old
- d1 spec deep dish steering wheel
- nismo short throw shifter and greddy gear knob
- clear blinkers
- vertex rear bar
- stanadard type-x kit all plastic original
- custom front LED blinkers
- complete standard type-x interior etc
- Alpine head unit and Fusion splits
- car completely Dynamated
-17" RAYS ENG. VR-X10 meshys 17x8.5 front 17x9.5 rear Toyo Proxy 4s
-alloy red wheel nuts/lock nut
performance and handling:
-Re-tuned ECU
-480cc injectors
-black top sr20det 83000kms
-t28bb turbo 13psi
-turbosmart boost T
-blitz dump pipe and down pipe into 3" zorst
-Greddy tube and fin cooler kit
-pod filter
-s15 injectors
-Bosh 040 in tank pump
-earthing kit
-JIC 3 way hight ajust, 15 stage damper ajust, camber ajust (month old)
-DBA 4000 slotted rotors and Project Mu drift Pads
-KTS soild rear cradle Mounts
-KTS alloy steering mount
-KTS Gearbox mount
-Cusco castor arms
-Cusco Front strut brace
-Nismo engine Mounts
-Xtreme Hduty clutch and lighten flywheel (done 500kms)
-S14 gearbox just installed
-Kaz 2-way 4-3 gears
-New whiteline swaybar link bushes*
-New tierod ends*
maintenance:
-new oxygen sensor(genuine)
-new water Temp sensor (genuine)
-serviced every 2000kms motul 300v crono
all fluids changed 500kms ago all motul products coolant,gearbox,diff,power str etc
owned for 4year from stock missus drives it done about 5000kms in 4 years
$16500 Now with RAYs ENG. wheels
$14500 no diff/coilovers will come with stock LSD and HKS shocks & springs
**price also NEG on removal of Parts**
Contact Alex- 0421340064
i can vouch for the condition of this car
type x's dont come much better than this one, prime example.
looks, sounds and goes amazing
plenty of good fruit
good luck alex
cheers
brad
good luck alex
cheers
brad
cheers man :P
*cream*
wait...
*moves to SA and buys*
haha good luck chammp!
thanks mate... on that note any interstate buyers welcome happy to ship
This is the way all 180's should look! very sexy car Alex : ) Type X's are best kept original and this one is a great example of one, free bump!
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
