  • Replies 45
Posted Images
  • 3 weeks later...
Box still available. Has GREX/GReddy billet centre plate (over $1,000 on its own).
Will come as a complete box with transfer case ready to bolt into your GTR.
hey mate,
how easy are the rebuild parts to source for this gearbox
also how often are you supposed to pull the box apart for maintanace and what not?
hey mate,
Box has new bearings. Gears and other parts are available ex-Japan.
Maintenance and inspection - depends upon how much work it gets, but I would suggest every 5 to 8,000 kms.
  • 4 weeks later...
Box is now sold!
However, I have sourced enough spare parts (including a brand new GREX billet sandwich plate) to build my spare Trust dog box as a complete item, the same as this one.
So...another TRUST dogbox for sale, freshly rebuilt with new bearings and new GREX billet sandwich plate. This one will be going into my car if not sold by the time it is ready to go :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
