  • Replies 85
yeah that red 32 won it and the jms 180 came second there were too many commonhores though but then again it gave us time to get drinks when they sent them fools out. ne1 cruising round the city after? i got soo ***** sunburnt. Where was the potition forrm bout regency couldnt find it ?? and did ne1 see the 4 door r32 roll it ?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
