Thumbs up to JMS for organising the event and to Danny for setting up a car (in such short time) for a demo show. Too bad the silvia died prematurely.
I particularly liked how the final 16 were eliminated - one on one. The closeness of each car while drifting made it a heck lot more interesting!
Maybe in future, we can have a St Johns crew on standby, should there be any mishaps or heat stroke incidents. Sat was ****in hot!!
ad
  • Replies 85
We just get a bit pissed off when after all our effort someone who hasnt done anything thinks they can come and bag us
Fair call - as I see it, you guys are doing more than anybody else out there to get drift recognised in this country - and its a good thing someone is doing it.
well we cramped 4 ppl in the 33 and drove from melb to adelaide and it only cost a canary, 2x $200 fines and 6points, full sunburn that blistered the same day and a bad hang over on the sunday.. but it was well worth it.. hope to be there again for the next 1
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
