I have now dropped the price down to $1900 ono as looking at one of the turbos it seems to have a small amount more shaft play then the other turbo about 1mm movement compared to about .5mm movement in the other it does not hit the housing or anything like that but not really sure if this is significant or not so i have dropped it down in case a rebuild is required dont want to stuff anyone around just looking to offload these pretty quickly as i need them gone before i head overseas.
Hey so i guess you use your standard actuators for this setup? or do they come with hks ones?
cheers
you can use your standard actuators or the HKS version but this set does not come with actuators attached
would u separate?
I might buy the other one...assuming these are the same HKS 2530s which work well on RB20s???? Can anyone confirm that these would be an easy bolt on or are they different spec?
