Item: Wolf 3D V4 (V400) with Hand Controller
Condition: good condition, no scratches on computer, slight mark on No3 button on controller(really nothing)
Price: $800
To Fit: R33 GTS-T and R32 GTS-T
I am selling a wolf 3D v4 rev 7. This is a plug in and play unit with hand contrller and cable and software for laptop. It is stickered Nissan R33 and as wanted it for my Rb20 I contacted wolf and was told it does both. tuned on the rb 20 on it with 520 injectors and gt35 turbo (yeah was ridiculously laggy hence whole new set up)
Some details on the Wolf unit (collected from other posts):
The Wolf 3D Version 4 is fully 3D tunable for both fuel and ignition timing!
These ECU's are an excellent unit with incredible tuning resolution, both ignition and fuel can be adjusted every 125rpm with 16 different load bands. This compares very well compared to Microtech that can only be changed every 500rpm with less load points. Having such a fine tuning resolution is perfect for getting the most out of your modified engine.
No need for a Z32 AFM with this ECU, simply remove your AFM all together.
Overall this ECU provides sharp, crisp throttle response whilst still maintaining factory drivability e.g smooth idle, fuel economy, cold start etc, something impossible with many of the competitors ECUs.
Some of the benefits of fitting a Wolf 3D V4:
Make the most out of your modifications
Excellent drivability, Wolf 3D V4 features full cold start and air temperature adjustments
Easily retuned if you change a modification
Crisp and smooth idle
Excellent fuel economy
Ability to remove AFM. ECU is MAP sensor based so no need for a Z32 or the airflow restriction a AFM causes
Boost controller can operate with factory solenoid
Can run multiple Maps with live map switching while the engine is running(Power Map, Economy Map, or Low Octane fuel)
Specs:
Tune from PC Software
Maximum Engine Speed 20,000RPM
Fuel Map every 125RPM to 16,000RPM
Fuel Map has 16 Load Bands
Ignition Map every 125RPM to 16,000RPM
Ignition Map has 16 Load Bands
Idle Speed Control with Water Temperature Compensation
Sequential Fuel Injection
(these details were pinched from a thread by skysaresilver)
Will try and post pics this afternoon.
Can post goods are buyers expense.
https://www.sau.com.au/forums/topic/312681-wolf-3d-version-4/
