hey hey
i got a hdi electronic boost controller with a boost guage n had it installed, after that was having issues with misfire and other things.
i then wired it up so i bypassed the boost controllers solenoid i thought this would run stock boost but now its running 12.5 which is way too high considering its on lowest setting.
any idea as to why its running so high?
https://www.sau.com.au/forums/topic/312992-boost-issues/
In the thread below SKYPER says that he has tested a few R32 wastegate actuators and they were higher then 10psi, they varied around 12psi.
http://www.skylinesaustralia.com/forums/Rb...-U-t312106.html
Plus a full exhaust so 12.5psi sounds ok. As Hypergear said remove the boost controller from the system and see what just the wastgate actuator runs at.
https://www.sau.com.au/forums/topic/312992-boost-issues/#findComment-5145471
thanks mate that gives me a bit of relief haha, thought i bought i dodgy boost controller, wasted 350 bucks.
ill run it the actuautor and see what happens, thanks guys
https://www.sau.com.au/forums/topic/312992-boost-issues/#findComment-5145482
well i got my spark plugs changed and the car is running well when im not using the boost controllers solenoid, still around 12 but i can deal with that for now. as soon as i put the vacuum hoses to go through the ebc's solenoid and take it for a drive the boost shot up to like 16 psi and was going to keep going untill i took my foot off the accelerator.
im 99% sure its wired up correctly, the ebc is a hdi sbc d or something, the one that comes with the really bright boost gauge, also if the key is turned on the acc should the boost guage be reading a number? if so what number, thanks
https://www.sau.com.au/forums/topic/312992-boost-issues/#findComment-5149166
Good work. So as you have probably worked out the wastegate actuator on your car operates at 12psi. This is a minimum boost pressure so you cant go below it.
When you introduce the boost solenoid it spikes to 16psi and above, so your boost controller is not setup correctly.
Sorry I cant help with that specific boost controller.
https://www.sau.com.au/forums/topic/312992-boost-issues/#findComment-5149181
haha thanks, i was told it was 10 by a few people so i was a bit confused :P
ive tried everyway the boost controller can be set up, looks like ill have to spend some more time trying to figure it out, serves me right for not going for the profec
https://www.sau.com.au/forums/topic/312992-boost-issues/#findComment-5149190
    • And I'm guessing my GTR might be feeling a bit unloved. Had to push it out to get the R33 out, but couldn't push it back in (its a bit uphill,  haven't got around to installing that winch yet, and Kel complains that its "too hard" to help push cars uphill after her double back surgery....kids these days) Hopefully I can get that winch mounted and get her back inside before a pine tree falls on her in the storms coming this week.
    • Yea all the cars run 295 cause f**k having different sizes
    • So, this happened today r33.mp4 No, I don't have much of a future on tic tac Yes, it needs a tune Yes, I cut the video just before I stalled it ....gotta be nice to fresh engine.
    • So I actually had the cover off my car today, here is a (bad) pic of the setup. I have an oil cooler thermostat block, the temp sender is straight in there. The pressure sender has a short AN line to a T piece which is mounted (hopefully cable tied counts as mounted....) on the chassis. BTW every fitting you could ever imagine exists....just depends what they cost and how many you need. Raceworx AN adapters are here: https://raceworks.com.au/fittings/adapters/, I think you said you need BSPT to AN (https://raceworks.com.au/fittings/adapters/bsp/tapered/an-to-bspt-adapters/) and AN to NPT (https://raceworks.com.au/fittings/adapters/npt/) BTW, braided line is super simple to make. It looks intimidating, is not.
    • Perfect day for a pie, really needs a soft top in this weather though
