Hey guys I'm just looking for some tenzo 18" wheels (+ tyres if possible) in black with red lip or all black that will fit a v35 2003 coupe, if you have any for sale please pm me cheers
forgot to mention I'm in Sydney - also these wheels might also come under lenso type m
Edited by ezy03
https://www.sau.com.au/forums/topic/313438-wtbeoi-18-tenzo-type-m/
  • 1 month later...
  • 3 months later...
