Hello predetor. Yes i do wona fix, i fkn hate that sound and sick of punching the **** out of the dash hoping it stops. OK so you have this part called the 'heater box', if you are mega positive that the noise will stop, then yes I will definetly buy it. How big is the part and how much is shipping, as I am located in melbourne, I am going to get it installed for free from my mechanic, so not a problem.
Is it doing it all the time, or just when you start up the climate control or make a change to the settings??
It must be major if its that annoying. Some only do it a tiny bit, and it never worries me that much. I have the relays, which are basically motors which open the vents when you turn up or down the temperature to mix the aircon and heating. Its the sound of them trying to open, and slipping and hence the ticking. There are three of them which control each of the different vents.
I can take the ones off shown and can send them to you for $30, let me know via PM.
  • 3 weeks later...
mmmmm those relay motors are not usually cheap, i had the same prob and ended up buying a second hand one from just japs for over $100 from memory... Fitting it was a task, apparently it is an extremely common prob!
its that poofter on the top of the box that does it....i have repaired one of them once...i think the gears strip out on one side inside the mechanism......the motor rotates but it doesnt use all the gear so you can take the little gear off and spin it around a bit......but you have to take the dash out to do this....about 1 hour out...1 hour back in...
Stepper motor not relay!!! relay annoying!!
Mine does it too but I can't fault the operation of the climate control.
I hardly ever hear it, Thanks remote start!
and if i tried to remove my dash it would take forever because of the insane alarm and tracking wiring!
So in short install remote engine start and you will hardly ever hear the stupid clicking noise!:D
I very well may, think my alarm sh|t itself, might as ewll get a new one wif remote start and auto window winder thingy when it arms.
Thanks heaps guys!
you will need a spare thousand dollars to get a name brand alarm that does that :)
motor/relay/doova/whatever... $100 ?!! I've still got all 3 of them sitting here, the guy who said he would take them never got back to me.. PM an offer if you want it.
  • 5 months later...
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
