If the comp doesn't change with the oil test then you could just remove the head with the motor still in, just be sure you do the oil test properly, with enough oil to ensure it get's around the whole piston, and not to much or this will give you false higher psi reading's, the other way to check is to presurize the cylinder with a fitting that screw's into the spark plug hole, with both intake and exhaust valve's closed on the power stroke, then listen for leak's through the intake manifold and exhaust manifold to verify a faulty valve, test each cylinder and see if their is more hissing on the cylinder's with the low compression, just remember to rotate the crack each time to get the cylinder your testing on the power stroke to ensure the cam's arn't holding the valve's open slightly,
could also be worn valve seat's causeing low compression because the gtr's run solid lifter's they need shimming to change the valve clearance, but with rb20- rb25's use hydrolic lifter's so they never need touching until one shit's it's self, or you get sick of the 10 seconds of tapping every now on start up and then and replace the f-ing thing,
If it was me i would pull the motor and check the piston's and bearing's and fit new one's anyway while you doing open heart surgery on your RB, then you know it's going to be a healthy rb, for a couple of hundred extra it's worth doing now rather than later,
You need to know how to gauge clearances for your bearing's, if your not confident doing this then leave the motor in the car and just do the head, if you get the clearance wrong it could throw a big end bearing and end the fun,
I found the ACL bigend bearing's to have a enough varience to swap and change until i had all 6 with the spec's i wanted, to the point where the thickest bearing would lock the crank up when i fitted it to one cylinder, if i had just put the bearings in any which way, the motor wouldn't have lasted 5 minute's, It's still going strong 2 year's 25,000km later with abuse all the time, shit that means another service is due on my rb,
Hope this helps out a bit,
Glad i started on an rb20, will not be so worried if i can pick up a cheap gtr with compression problem's
you found enough varience to lock up the crank in one position? you got the wrong bearings.
  • Replies 42
Not completly lock up just tight tolerences sorry miss worded it,
RB cranks have slight variences when measured with micrometer's and ACL bearings also have slight thickness variences
If i fitted the wrong bearing's would the RB still be going strong after 25,000km, No it would not
how many RB's have you rebuilt?
with new rebuilt pistons, rings and bores, what is the top compression rb26 have???
Hi Andy
From the factory a brand new RB26DETT will have this compression Compression Pressure: 171 psi / 300 rpm
Did anyone know an R34 GTR V spec is 44 pounds heavier than the standard R34 GTR, That doesn't seem right you'd think they would have shaved weight of not put it on, Probably all the V-spec badges they add, LOL
Edited by skyline4lifer32
1 rb25det plenty other engines,i dont talk crap.
I don't either, I built the RB20det with tight tolerances because of the thinner synthetic oil that it was built to run with, Stock clearances didn't suit the oil, If i was just going for stock clearances then i wouldn't give a sh!t about the small differences
does building aircraft engines count?
Yes it does, probably more so because a f*k up in the air means your in a plane that glides like a brick thrown through the front window of a popo car,
What aircraft do you work on?
And I forgot to mention that a wet test won't help with a holed piston or missing ring segment either.
hmmm i can see from the plug holes...there is no hole in the pistons, if the piston is holed, if won't give any compression...
ok... sorry... i was wrong, my pressure tester, is a mistake, now... i can hear the leaking air but i cant find it... its not on the oil dip stick... its somewhere in the cylinder head... sometimes when i tried to turn slowly the cams, the air will out on cylinder 1
Edited by andy95'R33GTR
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
