Im not sure if the gts-t and the gts have the same interior besides the dash....
anyway, ive got a non turbo r32 gts and i want the following interior pieces:
  • left passenger side air vent.
  • left side mirror (gunmental gray preferred)
  • backseat left and right interior quater panels
  • gearstick and handbrake leather blackcolor.
let me know if your selling any of these or if u know of any online stores that sell these.
thanks.
Hi man
I can help you with all these parts all in perfect conditon with no damage
the g/boot and hand brake boot near new 150.00 plus postage
stuart 0409135950
thanks.
mirror in black good cond $30 + post im in perth
