Hi All,
Selling my Explosion bodykit for R33, which was purchased from Jetspeed. Included are front bar, side skirts and rear lip. Damage shown in pictures, $400 for the lot
What it looks like on R33 GTS-T (P.S. Those wheels will be advertised next weekend :unsure: )
Also for sale, Cannon muffler for $50. Nice and loud, defect material
Located in Campbelltown, South-West Sydney. PM me / Contact me on 0413 550 783 if you have any questions
how big is cannon, inlet and outlet., keen to buy, and how much for front bar seperate???
3" inlet, 5" tip. Otherwise that I'm not too sure on the measurements so let me know what else you need.
I'd really prefer sell the kit as a whole but if so. $200 for front bar, $150 for Side Skirts and $50 for the Rear lip.
Front bar's damage: stress fractures at wheel arches, crack underneath the middle and just some scraping underneath.
Side Skirt Damage: Just some scraping along underneath.
Rear Lip Damage: Just the tear pictured
how much for the wheels bro???
Still on the car but going for sale next week for $1200. The wheels are 19" RPM 'Hiro's' (8.5" Fronts, 10.5" Rears) Front tires fine but rear tire treads getting thin on the inside because of camber angle. Veery slight gutter rash on the edge of lip on 2 of the wheels, but spokes are perfect
hey mate, I'll take the cannon for $50 if it includes postage?
Sorry, postage at buyers expense. If you are seriously considering, let me know where you are from and I can get a quote for you
SORRY I HAVE MADE A MISTAKE, INDICATORS + FOGLIGHTS NOT INCLUDED WITH FRONT BAR. I forgot to remove them when I took the photos :thumbsup:
I am hanging onto those, sorry for the false advertising
Edited by bt23
  • 1 month later...
SORRY I HAVE MADE A MISTAKE, INDICATORS + FOGLIGHTS NOT INCLUDED WITH FRONT BAR. I forgot to remove them when I took the photos :)
Hey man you can call me on 0449198445. Thanks
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
