  • Replies 104
handbrake ratchet
Yes
Hey mate,
Was wondering if you had the Brake Master Cylinder available?
and yes
Steering wheel for sale?
And still have the Strut brace + photos?
Cheers
Series 2 steering wheel is on hold atm, I do have a series 1.5 available though, also in very good condition
Rear strut bar is sold, front is still available
Which brace were you after and I'll get photos
What kind of cat do u have? Price and willingness to post?
It LOOKS kinda like a cat externally, but has a 3" pipe shoved through it and welded to look legit
Willing to post but at your cost - roughly $20 post and $50 for the "cat" :P
Engine/Driveline stuff
RB25det - complete engine with all ancilliaries - $1250 SOLD
Garrett GT3076R BRAND NEW - .6 surge ported comp cover, .86 exh housing, external gate - $1600
Garrett GT3582R exhaust housing, .82 - $250
Jun "style" inlet manifold, still over $800 new on ebay - $600
BMI 86mm billet throttle body - $250
Deatschwerks 740cc injectors (straight fit in factory rail) - SOLD
SARD FPR, with gauge and adaptor for factory rail - SOLD
Walbro 255 l/hr intank fuel pump, BOSCH 044 external and 500ml surge tank, with all fuel hose required for fitment - SOLD
Performance-wise Oil cooler and filter relocation kit - SOLD
MSpec aluminium radiator, pretty sure it's 45mm - SOLD
KTS Intercooler, 600x300x100, 3" in and out - $200
FMIC, 600x300x70,3" in and out, BRAND NEW - $150
Tial 38mm wastegate, slight grinding marks from fitment, perfect working order - SOLD
Highmount steampipe manifold with merge collector (similar to 6boost), T3 flange and WG flange for Tial gate, will need WG pipe modded to fit a 25, straight fit for 25/30, HPC coated - SOLD
Excedy twin plate clutch, plenty of meat left - $1000
Lightweight chromoly flywheel, good condition - SOLD
RB25det gearbox - was perfect previously was a bit clunky going into gear after i dragged it through the tunnel with the shifter in (only driven for 200 metres since), hence price - $1000
5Zigen 3" cat-back exhaust with oval muffler, quiet and was flowig 450rwhp - $250
Splitfire coil packs, perfect working order - SOLD
JJR GTR polished alloy washer bottle replacement with oil catch can, has been separated but can be re-welded - SOLD
Turbosmart Type 2 plumb-back BOV - $150 - SOLD
R33 non ABS diff, shimmed a few years ago, still nice and tight - $100
Suspension/Brakes
Sydneykid whiteline/Bilstien springs and shocks, circlip adjustable, 5000km use - $1000
Whiteline fixed front and rear swaybars, not sure of size but the biggest fixed ones they make - $350
Adjstable Rear upper camber arms - $100 - SOLD
Front adjustable castor arms - $100
Front strut bar, polished - $100
Rear strut bar, factory - SOLD
Front brakes, with RDA slotted rotors and Ferodo DS2500 pads, hardly any pad wear - SOLD
Rear brakes, stock - $150 - ON HOLD
Starcorp Impul rims, white, deep dish rear, 18x8.5 F, 18x9.5 R, some gutter rash, ss595 rears with 75%, Nexen fronts need replacing - SOLD
Electronics
Haltech E11v2 with R33 patch loom and 3 bar MAP sensor - SOLD
Blitz dual SBC EBC, the older black one, dual solenoid good working order - SOLD
NISMO clear side winkers - SOLD
Auto gauge 2 1/4" inch stepper motor gauges, smoked, with all senders - Oil Temp, Oil Pressure, Boost - SOLD
Pioneer CD/MP3 headunit, basic model, black, removable face - $50
Jaycar response 4ch amp - $100
Fusion 12" sub in box- $50
Body & Interior
Garage Defend carbon fibre air guide, perfect fit for GTST, good condition - $400
NISMO GT shift knob, excellent condition - SOLD
Series 2 steering wheel, very good condition - $150 - ON HOLD
Series 1 headlights, sedan model with silver inserts, excellent condition - $300
Rear lights, black - $50
Series 2 rear wing, black, with boot - $100
Type M front bar, black, stone chips so needs paint, meshed with high quality case mesh - SOLD
Type M side skirts, good condition - $150
400R side skirts, 1 has a slight crack otherwise a really well made set of skirts, gunmetal - $150
Type M rear pods, black, good condition - $80
Series 1 dash surround, very good condition, has been stripped and repainted - $100
Centre console with gear surround and ashtray, good condition, gear surround stripped and repainted - $100
Drivers side window switch panel - $100
Series 2 seats, front and rear, drivers side has tear in bolster - SOLD
Interior carpet and boot trim - $60 - ON HOLD
Seatbelt stay, the swinging thing that holds the seatbelt off your neck - $40
still got grill mate if so how much to get it to hobart?
call me or txt on 0408802254 (wont let me pm yet)
cheers
jeremy
cheers
jeremy
Grill is sold
hey dude,
have u got the rear cut with parcel shelf and childanchors? cheers
Yes I have a parcel shelf but I doubt it would survive the trip to VIC, they are pretty flimsy
how flimsy are they? isnt that just a piece of metal?
mines been cut out for speakers... kinda confused... :blink:
mines been cut out for speakers... kinda confused... :(
I thought you meant the actual parcel shelf (that's made of some type of chipboard)
My rear shelf had been cut for speakers as well, so cant help with that sorry
You know if the S1.5 wheel airbag plug will fit a S1?
S1 didnt come with an airbag so not sure which plug you mean
I had it on my S1 with no issues
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
