Available:
Update! 26/5/2004
Pictures HERE (click)
These parts are available. If it is not listed here then it has been sold or is not available. Please do not ask for parts that are not listed here or I will give you a ridiculously high price and after you've paid for it, I'll go to a wrecker and buy it really cheap and send it to you.
phorj now has all of the parts, please PM him with enquiries:
http://www.skylinesaustralia.com/forums/pr...do=newpm&u=1333
KYB Gear Climb struts. RS*R springs $300 ono for the front pair
Quarter Panel black (click) $150 each
Steering rack $100
K-frame $75
Power steering pump $40
or rack, K-frame and pump for $150 together
Manual pedals set $150
Clutch master cylinder $30
Steering column with 2 keys $20
Brake Master Cylinder & booster $80
HKS Turbo Timer $40
Alternator $55
Castor Rods $40 each
Front hub $20 each
Front upper control arm $20 each
Front lower control arm with ball joint $75 each
Front 1/4 panels $150 ono each
Windscreen Washer bottle $20
Radiator overflow bottle(missing cap) $20
HVAC Fan Blower: $20
HVAC unit: $100
Dashboard plastic Garnish inc vents and buttons $100
Instrument Cluster Garnish: $30
Hicas sensor unit for standard steering wheel: $10
Indicator Stalk assy: $40
Steering wheel surround (Has small mounting holes where turbo timer used to be): $10
Sold:
Engine RB25DET (inc turbo, intake, exhaust, loom, ECU, airbox, clutch, everything)
Gearbox
Bonnet
Headlights
Bumper & support
Radiator
Radiator support
Castor rod mounts
Front Brakes; 4 spot calipers,Rotors.
Air Conditioning compressor
Air Conditioning condensor
Steering Wheel
Dashboard
Glovebox
Climate Control button assy
Located in east suburbs Melbourne. Will ship interstate at buyers expense.
Direct deposit or cash only.
https://www.sau.com.au/forums/topic/31465-wrecking-r33-gts25t-black-ser1-melb/
  • Replies 90
i will get the dash garnish from around stereo and steering wheel if in good condition + i need the plastic trim from drivers arm rest + plastic from around the gear stick and cig lighter + also need plastic from under dash that cover all of the fuses(under steering wheel)
and i also need the dash pad if in good condition is it possible to get these parts sent anywhere in vic?
SkylineGeoff - I am not certain whether or not the recepient of the engine requires the air con compressor, I will get back to you early next week.
Predator - will answer your Q on Saturday by the time I've pulled it apart that far.
EnricoPalazzo - Sorry dont have rear half of car, should have mentioned in first post.
lindsey34, check PM
--edit--
dave, sorry to you too, I should have mentioned it was only a complete front cut, I'm missing everything from behind the gearstick. No doors unfortunately.
gtrGhosTDoGG11 - no, why do people ask for the control panel? Is there a common problem that the windows dont want to move with it? I've repaired one in the past, it was only dry solder joints. They dont look dry, use a relatively powerful electronics soldering iron (30w so no plumbing irons :() and go over each joint. Should work afterwards....
Bozz thanks for quick reply. The reason I am looking for it is that in the bottom of the pocket there is a screw which holds it down. The plastic has cracked in it so its not being held down.
I guess I could probably fix it now Ithink about it :S
Bozz
as well as the other enquiry I made regarding the A/C comp, I'll be happy to take the Steering wheel off your hands at that price. I'll wait for an answer on the comp before arranging to come and pick it up.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
