Up for sale is 1 of the 2 bride low max replicas i bought. im strapped for cash so seeing as i dont really need both of them im selling one. These are good chinese quality seats with the exact same detail as the real things and has the bride imprint on the metal bit of the seat on the side. seat also comes with universal double lock slider rails that i paid extra for because i didnt want the standard shitty rails. im looking for 650 for the seat and its located near the kingsgrove area nsw.
https://www.sau.com.au/forums/topic/314654-new-bride-low-max-replica/
would be the same as the real thing so im sure they would be on brides site or atleast on google or something id assume. i can take the dimensions after easter because the next few days ill be busy running around
