New thread as old was clustered and outdated! need these gone
R32 Whiteline strut brace New $80
pic 1
pic 2
Blitz SBC Spec R $280
Bought second hand off ebay to fit onto my skyline, never got around to it now im selling the car. Item is second hand with slight blemishes. There is glue on the case from where it was mounted onto the dash. This should come off with some heat and patience. I never fitted it so don't know how to install or configure please do not ask, but im pretty sure there are intruction manuals on the internet. Comes with all that is displayed in the pictures and should be everything you need.
Freatures:
* The Blitz Dual Solenoid Boost Controller R (Dual SBC Spec R) has four programmable boost settings or various levels of boost.
* This unit features a built-in boost gauge, peak boost display, four different boost settings, boost warning, scramble boost, and a boost limiter safety feature to prevent over-boosting.
* The Dual SBC Spec R uses a dual solenoid design for maximum boost response, capable of handling boost up to 2.5 bar (36 psi).
* The Dual SBC Spec R is 1/4 Din size and is compatible with internal actuators and external waste-gates.
Pic 1
pic 2
pic 3
R32 Rear pods $40
Maroon in colour. Been in storage. One has a large crack as can be seen pics. Few scratches and scuff marks. The price reflects this.
Would suit repair and respray
pic 1
pic 2
pic 3
R32 Greenlabel AFM $30
Used, was working fine when last removed. Has been in storage for past year.
Cannot gurantee it works 100% but again it was working when last used. This is why its going cheap.
pic 1
pic 2
R32 stock rubber intake pipe $30
Pic 1
Brand new Bosch R32/R33 Starter motor $80
pic 1
Pic 2
Pic 3
All items located in NSW Liverpool area and can post all at buyers expense. Want this stuff gone guys its just sitting around! Everything dirt cheap
R32 Rear pods $40
pic 1
pic 2
pic 3
pic 1
pic 2
Pic 1
I Will take the rear pods AFM and intake pipe if ypu will post to adelaide
Cheers Scott
hey bud im kinnda new to this
im not sure if its better if i can get a contact number and we can discuss
pick up its not sold yet cheers
  • 3 months later...
Blitz EBC back up for sale due to times wasters. Want a quick sale grab a bargin!
Is the Blitz EBC still for sale?
Im interested?
location in sydney?
Edited by Jamo30
Hi Dave. Did you end up selling the "blitz boost controller"? If not what do you want for it? I`m in Melbourne so i`d want it sent down, so give me a price delivered.
  • 3 months later...
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
