I have a Nismo combo meter for sale, it is in perfect unmarked condition in its original box.
price is $300 including express Postage.
Genuine Nismo short shifter. For R34. It has been fitted to my car for a couple of days then taken out. It is a 10% reduction on factory throw.
You will need to replace the plastic bush on the end. (not sure what its called, get it from nissan $5?.)
$100 including express Postage.
Spewing those nismo clusters are in orange writing and not white to match the rest in my 34 other wiser I would snap this thing up
Free Bump
Giulian
Ok, Nismo solid/short shifter is available again.
I removed it from my car before i sold it to gain a little $. i paid around $280
http://www.nismo.co.jp/products/competition/mission/pdf/clutch14.pdf
Does it mean It will fit NA R34 also? as well as RB20 na r34.
part number from nismo website: 32839-RNR40,
Location Wollongong NSW. Thanks
G'day, it needs a new bush because i reused it on origanal shifter. I dont know for a fact if its available, i havn't checked.
Im sure you can get one tho. If not, you could reuse your own.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
