I looked at the same welder str8...no water-cooler? I bought a chinese water-cooler and it works a treat and a sh1tload cheaper than the stuff that comes from kemppi, lincoln or any tig manufacturer
230amp, single phase seems good and they have a great reputation....I was just over inverters since I had nothing but bad luck with them.
https://www.sau.com.au/forums/topic/315225-welders/page/2/#findComment-5276652
the unit i just bought is air cooled
i thought about going water cooled but im not on the tig all day the machine gets breaks between welding while im cutting and grinding and or that sort of stuff so i didnt think a water cooled unit was needed
i use a lincoln at work and ive only ever used it on stick and when i had a stainless job and had to switch it to tig it just stopped working and i had no out put so when it came time to buy a personal welder i went with kemppi
If you dont want to fork out for an auto darkening mask... Get a really big spotlight for your welding station. ha ha ha
I've found the snap on auto helmet to be awsome- relativly cheap in the US
J.
this is the one i use at work
got given to me by another working when he became a supervisor ( he no longer needed it because he wasnt on the tools any more )
i love it
https://www.sau.com.au/forums/topic/315225-welders/page/2/#findComment-5276676
reason I like the watercooled torches is because of the tight spaces you can get into with them...not only that, they are easier to keep a hold off and I find leave a better looking bead....nothing to do with how much welding I do. If I do 2 or 3 hours on the weekend, that is the heaps, like you, the preparation is the time killer.
https://www.sau.com.au/forums/topic/315225-welders/page/2/#findComment-5277615
isl33p... i just checking your cigweld transtig on another forum.. didnt realise you were selling one.. and ive just bought the exact same thing...
did you have any troubles with it?? simple to use etc?? did most things??
havent had much TIG experience before so im looking forward to learning.
https://www.sau.com.au/forums/topic/315225-welders/page/2/#findComment-5278524
Its the first tig I ever bought. Not bad, but just sucks too much current for a single phase machine. better connect via 3 phase. Worked ok, but a very basic machine....they will never die...they live for ever.
Definately could not have done the stuff in my welding pic thread :D
https://www.sau.com.au/forums/topic/315225-welders/page/2/#findComment-5278838
its my first.. so i figured id get a decent quality machine with fewer knobs and learn the basics... no point having 10 different settings for 10 different things if have no idea what they do or how to get them right to lay a basic weld.. id be constantly chasing my tail :D
https://www.sau.com.au/forums/topic/315225-welders/page/2/#findComment-5278966
Good thinking. My current welder only has amp control, penetration adjustment (frequency), pulse setting and post flow....thats it so there is no real need all that adjustment. i have seen the best welders produce the same results regardless of the machine and its settings.
The more basic and the less adjustments/options and there is no choice but to learn how to produce the best possible result with as little as possible....that really shows the difference between an average welder and good welder.
https://www.sau.com.au/forums/topic/315225-welders/page/2/#findComment-5279015
thats a very good reason
when making manifold collectors u dont have much room to work with
i just switch to a smaller torch when it comes to manifolds
might think about getting a water cooler
https://www.sau.com.au/forums/topic/315225-welders/page/2/#findComment-5279453
if you like, I can give you the details of the shop I got my cooler and torch from. around $1000 compared to $2-3k for the original kemppi ones.
post it up or pm with that shop too - the kempii at my shop needs a water cooled torch bad
https://www.sau.com.au/forums/topic/315225-welders/page/2/#findComment-5283418
  • 1 month later...
  • 3 weeks later...
Its all in the speed and the weave, and practice.
I am a first class metal worker by trade but not working with steel ATM, but give me a hour or so to get back into the groove and it doesnt look half bad.
My tip is to make up everything and anything, if you can get neat with good penetration you can pay for your gear by doing jobs for the boys, rip of as much material from work as you can and start stockpiling.
Also look into polishing gear for finishing.
Having you gear mobile is a huge plus to as you can fab up at peoples homes and workshops when you get good.
^^^ same boat as me. its the only way!!!
im yet to buy a tig, ive always taken works welders home for the weekends, getting tired of that very fast thou!!!
as for the helmets. i just use a standard helmet. change the lenses if i have to but i dont usually.
we do the highest grade stuff at my work. i know i sound like a tool but pharmaceutical tanks is the top!
neeeeeesd to get ac/dc tig asap!!!!
https://www.sau.com.au/forums/topic/315225-welders/page/2/#findComment-5404057
  • 1 month later...
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
