First up reason for buying a motorbike is that i lost my license for 6 months which is in effect quite soon and i need to beable to get around.
basically since will be on Ls maximum is 600cc's but i would like to get a 250cc one as i dont need all that power etc and the 250s still go well.
my first thoughts on this is i would like a good lookin sporty bike for under 3-4k and i will be getting 3rd party insurance as its such a cheap bike
I live in sydney on the north shore so any help on this subject would be good, any good places to get bikes, models i should be looking at, tips, insurance choices and anything that you can think of :)
This isnt a whoring post so do that elsewhere!!! only helpful advice please :)
Thanks all!! :(
https://www.sau.com.au/forums/topic/31540-buying-a-motorcycle-help/
I thought you couldn't do that anymore? (loose your car liscence and get a motorcycle liscence while on disqualified status)... have you looked into it?... I know you used to be able to do it but i'm 90% sure they changed it so you couldn't (only in the past few years)....
Also, I thought all L platers where limited to 250's... and even at that there are still 3 (from memory) that you can't have 'cause the power to weight ratio is too high.... One of which is the Aprilia RS250...(bummer that)... can never remember the othas....
can you elaborate if i am wrong in my ussumptions?....
Dave.
I was under the impression that if you lost one licence you can't get another type (eg lose car can't get a bike licence?).
Yamaha YZFs, Honda CBRs are fairly cheap and pretty easy to ride. Should be able to pick up a 250cc 2nd hand for somewhere within that price range.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
