sorry don't know how to edit other thread.
So now engine and gearbox is gone, i'm stripping rest of the car.
Car is a 95' series 1.5 r33 gtst, silver in colour. No quarter panels, front or rear bar as bodykit is completely moulded on :cool:
Items are located in Dandenong victoria, still in vehicle so will need time to remove.
will post at buyers expense for easily posted items. pick up for larger
EXTERIOR & ENGINE BAY
Item: Boot with series 2 spoiler and light in charcoal grey
Condition: no badge, slightly scratched
Price: $80
Item: Mirrors
Condition: fine
Price: $100
Item: Washer bottle
Condition: great
Price: $20
Item: Radiator w/ shroud
Condition: No leaks, rusty water ran through as had leaking water pump
Price: $40
Item: Pink label AFM
Condition: Working perfect, 1 broken mounting braket hole
Price: $80
Item: Airbox and snorkel
Condition: perfect, with 1 week old k&n panel filter
Price: $100
Item: Full 3in turbo back exhaust, 2 1/2in cat, 3 inch muffler w/ 5in tip
Condition: great, sounds tough too
Price: $900
Also have front and back windows (make an offer), Doors with windows and window reg complete.
Also have headlights and bonnet but maybe sold, so will keep you informed.
INTERIOR
Item: back seat complete
Condition: slight fade from sun, no tears whatsoever
Price: $80
Item: Front seats complete
Condition: no tears or fades whatsoever
Price: $200
Item: door trims driver and passenger complete
Condition: great
Price: $100
Item: dash faschia? the bit that goes roung the streo and over steering column
Condition: been sprayed mat black from a can, no damage
Price: $30
Item: climate control unit
Condition: perfect
Price: $60
Item: seat belts, complete set w/ bolts
Condition: perfect
Price: $80
Also have dash cluster reading 138,000k's, make an offer
No pics at the moment but can if necessary.
Contact : Brad 0422056446
Pm, SMS, or phone call
All in Dandy? I mite come have a look on the weekend if thats ok. I'm chasing a few things for my series 1.5. PM me your number if thats cool
Just read you number. My bad still half asleep. I'll give ya a call
Edited by adzr33
no worries mate. when ever your ready
Climate control unit solddddd
Parts added
Roof lining: $10 (1 or2 dirt mark,easyto get off)
Roof lights: $20 both (both fine)
Back seat side trims: $50 both (perfect condition)
Parcel shelf: $10
R33 s1 bonnet: $150 with water jet and heat shield,no dints
R33 s1 passenger headlight: $70, slight yellowing but structually perfect
R33 boot with veilside: $180, not much usage as it wasn't to my taste
if any one comesto pick these items up and pays liste price i'll install it on the spot for you.
not that much of it is hard haha
how much you want for the washer bottle motors? And did they work?
is that the two plugs attaced to the bottle itself.
$20 comes with free bottle haha
definatly both worked
Please PM me price for radiator shroud (if great/perfect condition) delivered to 2087.
Also air diverter actuator (fresh/recycle air actuator) please!
-Steve
Pm sent randy
and up it goes.
Come and get it. new car won't fit in garage if this stuffs here
Any one interested in a complete complianced shell. no engine, no gearbox, no diff,
has wide bodykit moulded on
hey mate do you still have the driver side window switches plastic? and the passenger side interior door trim with the window switch and where abouts do you live
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
