hi all, i bought another skyline w00t but im a bit confused about wtf the guy did before me when it comes to styling
its a 1993 skyline so its a series 1, but its got series 2 head lights. what im not sure about is, does fitting series 2 headlights require a new series 2 bonnet/guards/frontbar/grill?
reason im asking is because i wish to change the frontbar over to another style, however im not sure if i should be looking for a frontbar to suit a series 1 or series 2.. i dont remember the bonnet coming down as much too (i used to have another 1993 r33 series 1) so its almost like the front end had been swapped to a series 2
could someone in the know please explain whats involved in changing it from a series 1 to a series 2 and if i should be enquiring for s1 or s2 frontbar/grill?
many thanks in advanced :cool:
https://www.sau.com.au/forums/topic/315530-r335-confused/
Depends how he has gone about fitting it i suppose and if its a genuine bar he fitted properly. Looking at the pic its got the series 2 bonnet, bumper, lights and grill. They are all different to series 1 so but i think the guards would be the same, hope that helps a little.
https://www.sau.com.au/forums/topic/315530-r335-confused/#findComment-5167197
more than likely a sign the car has been in a front end collision. or he really wanted a s2 but didn't want to pay for one.
as for changing front bars, if you are going aftermarket then it shouldn't make much difference as it shouldn't be affected by the lights or bonnet, etc. in fact you could probably even put a stock s1 front bar back on and have it all fit up.
https://www.sau.com.au/forums/topic/315530-r335-confused/#findComment-5167331
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
