$3000 was on - je forged pistons. acl race series bearings and gaskets. bored 20thou over, acid bath,final clean,all new welsh plugs, crank cleaned,polished and regrind, ther was a couple other things just dont have the reciept here.
i will b using this car as my daily driver, and it will not really be seeing the track.
think i will use the crank collar i have here and possible go a new rb25det oil pump.
with the restictors - the block i got aparently has them in. how do i know?
i will contact southside cylinder heads 2morrow.
Do GTR valve springs fit the rb25det head?
Just get a workshop to fit your existing collar. As long as they grub screw it as well, there is no issue.
Your rb30 block will have restrictors, just not the right ones unless the workshop has fitted them. Seeing has your still not sure on which pump to run, I probably doubt they have fitted them. To tell if there fitted you measure the internal ID of the restrictor, stock is 2mm, 1.5 is what you want. Do a search for "oil control" or "restrictors". There is a guide to which restrictors to use for most configs and pumps.
GTR valve springs I can't answer, someone else might be able to. I know the rb26 head uses solid lifters, where as your rb25 use hydraulic. So I would say in order to use 26 springs, you need to do a solid lifter conversion as well.
Which by the time your done with labour, you could have bought a 26 head anyway. Just check out these guys:
http://www.performancesprings.com.au/
They do an aftermarket spring for the rb25det. Back in the day myn cost about $400 fitted. Springs aren't an absolute requirement but, it's only really to avoid potential float, and then give you the ability to larger cams latter down the track.
Edited by James_03
guy i bought the motor off said he had installed the oil restrictors, ill check it on my next day off work.
ill check that site out, i am planning on going aftermarket cams anyway.
i have decided to go a rb26dett oil pump, i can pick 1up new for $550. i will take the crank back 2my machine shop on tuesday and get them 2fit the collar.
How are you going to mount it down low enough so it doesnt hit the bonnet?
will just have to cut a hole in the bonnet i think.or space it up on the latches. i am going 2be using a front facing plenum so it shud help with clearance issues
  • 5 weeks later...
i have been told my block has the oil restrictors in it already,but am unsure how to check if they are.i am using an N1 pump,so what size should they be?
slowly collecting all the parts i need and will start putting the motor together this weekend.
my progress so far - and parts i have got.
Rb30 block -
decked
acid bath
bored 20tho over
JE forged pistons
standard rods - shot piened
crank cleaned up and machined
crank collar
N1 oil pump
ACL race series bearings and gaskets
Oil restrictors - unsure on exact size,but a 1mm drillbit fits in the front restrictor easily, but doesnt fit the rear.
Rb25det head(unsure what series)
full recondition and check
valve seat regrind( race grind)
aftermarket heavy duty valve springs
new seals
280 inl/ext kelford cams 9.5 lift (paperwork i have says they are drag racing cams)
Gates adjustable cam gears
Turbo -
Garret Gt35r with .82 rear housing
Tial 38mm external wastegate
have got an rb20 engine cross member and brackets,will also be using ford cortina engine mounts - hopefully it will get the motor sitting low enough so i dont have 2much issues with bonnet clearance.
any idea on what kinda power figures i could expect to get with this set up?
what size injectors should i be looking at getting?recomend any brands?
also what fuel pump should i get? have been told that i should consider using multipul fuel pumps and surge tank.
what water pump is recomended to keep the motor the coolest? i am considering using an electric water pump - thoughts? remember this is going into a 180sx and the biggest issue i am going to have is keeping the underbonet temps as low as possible.
the guy i got the block and head from had already put some oil restrictors in. And the block and head have had the external Oil feed modifications done.also the hole in the head for VCT has been blocked. Q. the cams that i am using are non VCT, is ther anything that i needs to be done to the head because the cams i have got are non VCT? do i just use the external oil feed and just block it off at the head and block?
any other advice or thoughts you wanna tell me,feel free
thanks
nismo 740cc injectors should do the trick but some 850cc sards should have you covered with some head room, what fuel pump will you be running?
your setup should be making roughly 450-550hp depending on boost?
in regard to the cooling of the engine, id recommend a koyo CA18 radiator with twin thermos on the condensor side as im pretty sure u wont have any room on the engine side.. and a decent fan controller with active temp monitorying and auto fan control.
electronic water pump, just another thing that can fail, dont bother wasting your money there
if cams are non-vct just block off the oil feed
Edited by snozzle
  • 1 month later...
so i finally got my motor in 2day.pretty happy with the way it is sitting. but having an issue with the gearbox crossmember. i am using an r32 g/box cross member with the letter C stamped on it,none of the holes line up and the gear stick isnt comming up through the floor in the centre - its forward a fairbit..
the other problem i have is that clutch master cylinder is hitting the back of the plenum - i have a greddy copy plenum.and clutch master cylinder has 5/8 writen on the side.
Any1 know how to solve these problems?
also can and1 tell me what the 2holes are at the back of an rb25det head. they are on either side of the bottom welsh plug. 1 is threaded and leads to nowhere, and the other isnt threaded and goes into the head somewhere
  • 1 month later...
Where do i get water feed to the turbo from? i am not running a heater or water cooler on the oil filter(rb25det have them) . Can i run it from the hole that comes outa the thermostat housing on the block? My block has 2holes for water on the exhaust side, but i have been told that i block 1 and use the other as water return from the turbo.what 1 do i block,what 1 is the return?
  • 5 weeks later...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
