gota clean out the shed, Lots of parts,
all cheap
R32 parts
complete right door with trim, $70
complete left door with trim, $70
gtst bonnet $100 type-m blue
gtst bonnet $100 primer
gtst bonnet, cut lip, needs patchin $50
right guard, $70
left guard $70
boot lid with spoiler, type-m $70
boot lid with spoiler holes, $50
rear bar $50
rb20det Block, has all parts, pistons, crand, rods ectt, just head removed, $100
front and rear suspension and brake setup 5stud
-discs
-calipers
-hubs
-caster arms
-upper arm stuff
- $500 for full kit
Full car wiring loom with all moduels and fuse boxez ect, $100
manual tailshaft $60
sway bar $30
gtst diff $100
interior parts, ask got lots,
gtst seats, front and rear $150
gtr rear seats, $200
R33 parts
complete right door with trim $70
s2 dash with airbag, mint condition $150
s2 front seats $150
R33 gtst front and rear, Discs, Calipers, Hubs, Caster arms, upper arms, complete setup $700
gtst s2 diff, $100
manual tailshaft $100
lots of interior parts, ask me
Need everything gone, got other parts i didnt mention
western suburbs, melbourne
i will only post small stuff, if you can organise postage for larger items i will send
0411980023
Edited by boz_soljah
https://www.sau.com.au/forums/topic/315717-cheap-r32-r33-parts-garage-cleanout/
hey man just wondering do you still have the
"front and rear suspension and brake setup 5stud
-discs
-calipers
-hubs
-caster arms
-upper arm stuff
- $500 for full kit" ?? and i was wondering how much do you think it would cost to send it to Adelaide ??
-discs
-calipers
-hubs
-caster arms
-upper arm stuff
still got it, pm sent
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
