Its automatic. You will get the 3 month suspension as usual or you can elect to live off 1 point for a year. if that 3 month is going to cause you hardship then I suggest you elect the 1 point and drive safely. If you lose that 1 point you will be suspended for 6 months. I sugged you not to drive while on your suspension because if you get caught it will be one year and court fees.
If you had say 1 point left on your license and you were speeding alot and you los say 6 points your suspension will be muchlonger like 6 months or something.
https://www.sau.com.au/forums/topic/3160-loss-of-license/#findComment-54058
yeah you're right. You get your 12 points back, but you acutally lose the excess in points striaght away that you owed them when you went over your 12 the first time round.....
Living on 1 point is pretty easy, just dont speed or do anything stupid and you should be fine, we all know how tempting it is from time to time to drag the ***** out of the car next to you, but when you got no points to burn, then its just not worth it say!
https://www.sau.com.au/forums/topic/3160-loss-of-license/#findComment-54163
Guest Boxhead
i dunno.. i have no pts left to loose, next thing wrong, and by by liscence, i have like.. 10 months to go till next liscence stage.. so basically the only time i speed, is on local roads where i know cops aint, and also when i see no headlights( for same area).. that way i know nobody sees and basically it would be a very very unlucky thing for me to get caught...
on the racing topic, make up an excuse, coz like, i have a rb20 na.. im the king of making up excuses not to race.. egs
*ive been booked for street racing twice this month, one more and they will confiscate my car
* i have practically no petrol
*i have no points left on liscence
*the car hasnt been serviced or tuned in ages, its due for one tomorow...
*one i like, is dont make eye contact, and play with stereo, or look at watch, or pretend to be on the phone...
https://www.sau.com.au/forums/topic/3160-loss-of-license/#findComment-54203
Boxhead sorry i have no sympathy for you
by the sounds of it you brought it on yourself, and and have to change your driving habits or lose the license until that happens from what you've said i would not drive with you or in a cruise in which your driving you just sound to dangerous.
i got down to 1 point as mentioned before and thats when i made a decision to change i needed my car for work, and work to keep my car. it was also costing me a fortune. I changed its easy, realised its theres a time and a place for everything and public roads generally isn't the place.
https://www.sau.com.au/forums/topic/3160-loss-of-license/#findComment-54382
    • I did basically the same procedure on a ZF6HP but the reason to pull the valve body is to replace the seals between the valve body and the transmission which are notorious for leaking pressure with age causing poor shifting and burning out the clutches. If you just wanted to exchange all the fluid you should be able to undo one of the transmission cooler return lines to drain into a bucket while using the pressure filler to keep it topped off.
    • The title should have posted "EFR7670 exhaust housing selection RB26" I can seem to edit thr title on my Android.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
