I am going to get a better exhaust for my 1978 C210 Skyline (L24) Fully Stock
I have the following options:
1. Extractors, 2.25" piping to lukey sports muffler to 2.5" turn-down tip - $970 all supplied and fitted at 1 shop
2. Buy extractors from another place ($440), install myself + $60 Engine Gasket = $500 then take to another shop to do 2.25" piping to sports muffler to 2.5" turn-down tip - $430 = $930
3. 2.25" piping to lukey sports muffler to 2.5" turn-down tip straight off existing engine manifold $400
If I choose option two, there is the chance that the manifold bolts could snap as they haven't been touched in 32 years, is the risk worth it?
What would you recommend for me?
I have also posted in WA thread.
https://www.sau.com.au/forums/topic/316008-c210-exhaust/
Hi,
Always keep in mind what the car is worth as you put more $$ into it. If you're just after a nice exhaust note, option 3 might be enough. However you do have a leaking exhaust manifold to fix, so maybe it's got to be removed anyway and you could replace it with extractors. Oh... and it might be a good idea to check your insurance - in case they consider it a 'modification'.
JH
https://www.sau.com.au/forums/topic/316008-c210-exhaust/#findComment-5173581
For a bog stock L24 2.25 is on the large side.
If your not really planning any other supporting mods it may be too much.
If turbo or nics aftremarket carbs/ecu injection is an option in the future then cool...
Have you asked for the same quote on 2 inch?
In my old sigma from years ago, it had a 2.6 4cyl, worked. when i went to 2 inch it lost some torque in the bottom end, but revvvvvvvvved like a motorbike.... 2.25 on a 2.4 engine is 'just' pushing the limits i think...
and the manifold bolts, well what i have done (on 4 different L24's) is just as i pull up in the garage, pop the hood, let it cool for a little bit, and while its still hot, spray a heap of wd40 on the studs/nuts. then leave it for an hour, then do the WD40 again but cold this time... and let it soak until the next day. they come undone so much easier then!
Dont use air tools, its why 99% of exhaust shops snap them, too much too quick.
if your having trouble undoing the nuts, get an extension for the socket set... makes it SO much easier. can be done in under an hour instead of 3 or 4! (no joke, its fekking TRICKY)
oh and pm send about extractors....
https://www.sau.com.au/forums/topic/316008-c210-exhaust/#findComment-5173956
In light of more information I have added a 4th option
Extractors to existing 1.75" pipe, (remove existing resonator) to lukey sports exhaust to 2.5" turn-down tip.
or should i change pipe to 2"?
MAG86: I haven't asked for 2", in my view going up 0.25" of an inch isn't going to do much, or does it?
https://www.sau.com.au/forums/topic/316008-c210-exhaust/#findComment-5174298
numbers 1 and 2 are no longer valid.
Revised options are as follows:
1: Extractors,2.25" piping, resonator, lukey sports exhaust, 2.5" turndown tip. = $1120
2. Extractors ($660 installed), existing 1.75" piping, new resonator, muffler(~$250) + 2.5" turndown tip (~$40). = ~$950
3. Existing manifold, existing 1.75" piping, new resonator, muffler(~$250) + 2.5" turndown tip (~$40)= ~$290
That's my options.
I want number 1, but don't want to spend that much so I'm fine with number 2, BUT will it bottleneck at the entrance to 1.75" piping?
Edited by Socrates
https://www.sau.com.au/forums/topic/316008-c210-exhaust/#findComment-5179339
  • 3 weeks later...
Alright i got exhaust done today
extractors, 2inch, resonator (hotdog), flow through muffler. $790 installed
Now my problems:
Extractors leaking and making hissing sound under load + fumes in car. = will take back to shop to get rectified
Heat riser, i was told that my car needs a heat riser, to warm up the fuel in the carby before it gets into the engine so it can burn better.
Exhaust shop can't make a heat riser from the extractors.
I can feel the engine surging when I put my foot all the way down, when it didn't before.
Is this something that can be fixed with a tune or will I have to either rig something to heat the fuel or just put back the old exhaust manifold?
I am planning to get carburettor overhauled and the choke pull of fixed which currently is stuck closed, until the heat opens it (which now i'm worrying about cause there's no heat riser so it's going to take longer to open and it's going to drive like crap for longer)
any help appreciated
https://www.sau.com.au/forums/topic/316008-c210-exhaust/#findComment-5217612
Fix the immediate problems before you make any elaborate plans.
1. Get rid of the exhaust leak. Extractors can be a bugger to prevent leaking if they are thicker, that is they stick out further from the head - than your inlet manifold. (Given only one bolt and washer is supposed to be clamping both the extractors and the inlet manifold to the head.) Your extractor place may need to make up some washers with little lugs welded to them to accommodate for the difference in thickness; it's probably only a couple of mm, but that's enough for exhaust to escape as I have found (emerging from my car smelling like smoke, eyes watering etc).
2. Get the carby rebuilt. The single carby is refreshingly cheap and easy to rebuild. I paid about $160 for an overhaul about two years ago.
3. If the car isn't right at this stage (and I'd be surprised) review your other options.
Good luck!
https://www.sau.com.au/forums/topic/316008-c210-exhaust/#findComment-5217797
OK i see, just droveto tafe now, cold start.
Drove absolutely shit, press accelerator and it coughs and chokes then starts to rev up, when normally it would only do it once or twice.
Is there anything else i can get to heat the fuel without using a heat riser?
https://www.sau.com.au/forums/topic/316008-c210-exhaust/#findComment-5217929
I've never heard of a single carb c210 with extractors (and I've driven plenty) needing a heat riser. I think the problems you have are related to poor carby cond or the exhaust leak.
Who told you that you need a heat riser? Don't trust/believe them.
https://www.sau.com.au/forums/topic/316008-c210-exhaust/#findComment-5220192
Place Called carburettor specialists, who said that he sees it all the time when extractors are put on and continued to explain how the fuel needs heat to become a mist to burn otherwise it will surge and etc.
This is the place that quoted me $620 for carburettor rebuild/overhaul, ~$360overhaul, $110 choke pull off (broken), rest labour.
https://www.sau.com.au/forums/topic/316008-c210-exhaust/#findComment-5220260
ok in all seriousness:
i had a chat to my mate about your problem. he is a speedway driver (won qld rookie of the year) in multiple classes and is also a pit mechanic for another driver.
he said the fuel heat riser thing is bullshit. in his commodore race car all the fuel lines are actually heat shielded because once fuel gets hot it evaporates and that's no good.
these were his pointers/advice:
-good chance that the bloke who did the work bumped some settings on your carb or something connected to it when he did the install. check all your lines. check the tuning.
-carby could be f**ked, period. just get another one.
-you may have put bad fuel in your car recently and has clogged the fuel filter. check fuel filter and replace if necessary.
pretty sure that was it. but yea ive had a c210 with extractors and standard carby without any problem too. doesnt sound right.
and that dude sounds dodgy. beware!
https://www.sau.com.au/forums/topic/316008-c210-exhaust/#findComment-5220969
Thanks for the advice mate really appreciated.
Got the carby tuned and it's running sweet now, just when it's cold(engine) and say driven for 5min and choke comes off it goes down to ~500rpm and tries to stall.
On the other hand I've found it has more power now as well, possibly a mix of extractors and good tuning.
Regarding previous problems,
Fumes - My Jap spec stovetop tail lights weren't sealed properly and when a window was opened it vacuumed the fumes from the rear outside the car through the gaps into the cabin.
All siliconed up and no more smells.
Extractor hissing - Been back to exhaust place, they say the extractors aren't leaking but the car still makes a hissing/muffled tapping sound when under load. Exhaust place says come back after the valve clearances have been reset and a service has been done.
Heat riser - Not needed
Surging - Carburettor tuning fixed majority of that, very rarely surges unless I'm in too high of a gear.
That's what I'm at now, I will keep you all updated on this
https://www.sau.com.au/forums/topic/316008-c210-exhaust/#findComment-5238977
Surging is like bursts of power, instead of all the power going on at once, it has small bursts of power and slowly accelerates until approx 3000rpm where it gains more power and accelerates rapidly.
https://www.sau.com.au/forums/topic/316008-c210-exhaust/#findComment-5239587
I'm very relieved that you didn't pay $620 for a carby rebuild, that is OUTRAGEOUS.
The car is bound to run a little average when cold, choke or no, they take a bit to warm up. I would mostly worry if the car ran poorly when hot.
Grab some tools and a service manual, and have a go at checking your valve clearances, ignition timing and cam timing. These things aren't to hard to check, but they all make a fair difference to how the car runs.
Good luck!
https://www.sau.com.au/forums/topic/316008-c210-exhaust/#findComment-5240530
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
