Do You Know A Ben Ellis Who Works(ed) For Zurich Financial Services?
It's been 2 years since I was scammed, see here: http://www.skylinesaustralia.com/forums/Po...le-t236106.html
I haven't forgotten about this and am still on the lookout for a Ben Ellis who works(ed) at Zurich Financial Services.
If you know this guy please send me a PM.
Ben if you are reading this start paying me back the money you stole from me, IT WILL NEVER GO AWAY
Edited by GHOSTrun
  • Like 1
contacted the authorities? perhaps contact "Zurich Financial Services" directly?
ill tell you what, if you found where the f**ker lived in sydney id be more then happy to go teach him a lesson in online etiquette... f**king can't stand scammers, hope you can manage to get you $$ back mate
Uselss. Absolutely useless!
2rismo (the admin here) did an awesome job, basically got me all the evidence etc, I gave the police the whole case file, left it with them for 2months, got a call back saying they couldn't do anything about it, I'm like WTF?!
It really shits me off! :blink:
  • Like 1
Sound tough mate...
I'd imagine Zurich Financial Services couldn't give out much information for privacy reasons too...
Try going to a lawer about it, see what can be done in terms of getting more information, also might be able to track the IP address of the SAU account with his service provider and that might get you an address even!
Good luck champ!
I've already spoken to my lawyer, the cost of following this up legally is just not worth it (i.e. would cost more than $1k to persure).
  • Like 1
Purely on principle...
and if I knew his address...
I'd feel like randomly picketing his place along the council strip - until he paid you back (with money that is...)
There's probably a niche market out there right now, where one hires a bag-lady with 10,000 flies following her to walk into nice respectable offices of scammers.
(Hell, there's even a niche market of busy execs hiring people to wait on queues for tickets to see something or land releases.)
Scammers enjoy the protection of anonymity. Embarrassment destroys that!!!! But hey, you've thought of that already eh?
Sound tough mate...
Good luck champ!
Service provider won't give you any such information, again, for privacy reasons.
It really shits me off! :)
the cops said they couldnt do anything???
similar thing happen to me i went to see the cops put my case forward mind you i had less info on the guy then you do so asides from his from his mobile number i had nothing.The cops then rang the moron while i was there and left a voice mail basically saying he was to either send me the item or refund me the money no excuses , the idiot rang back the cops said item was on the way... i think i ended up getting close to what i paid for about a week later.
Edited by Hiroshima Screamer
My mate have a same problem with cops
his evo got broken in and took his boost controller turbo timer headunit iphone and other stuff. Apparently cops said to him cant do anything not enough finger prints to build case....
if you ask me cops are a case by case thing , some are more then willing to help and some cbf'd with the paper work , its that simple.
i think one knows when the authorities have "exhausted" every avenue , in which case its different and at the end of the day they arnt going to call in swat lets be realistic.
  • 1 year later...
  • 1 month later...
Do we get to gearbox him now?
Don't know where he lives...
Surely someone must know the guy or know someone who knows the guy?
I think he used to own an R33?
Edited by GHOSTrun
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
