Put some black silicon on the thread.
^^^ This.
That's an odd place to leak, and I doubt you'd have much air leaking from there anyway.
You wouldn't even be able to measure a leak that small, let alone notice a difference in power :D
look for more leaks in cooler piping etc......
Oh an BTW, that wont damage your turbo at all if left, but take the comp housing off and fix it anyway...
If ur leaking from there im pritty sure uve got a bodgy O ring install prolly got jammed when the core was put in ... ive seen it done b4 but i spotted it b4 it was installed so we fixed it up but yeh man maby the O ring is damaged...?
found most of my leak from the cooler piping hoses when i did the boost leak test.. tightened the clamps and no more leak.
only from the bolts that i showed in the pic.
i tightened all 3 top bolts but the bottom bolt (in the pic ) still leaks.
will do the test again since i only did the test at 5 psi ( maybe try 7) which took a while to hit
the car feel abit better then before but the power feel linear compare to the stock turbo. (im guessing there still a leak somewhere)
i'm running stock actuator with the solenoid removed 5 psi( have a hks adjustable actuator as well)
stock airbox with apexi panel filter
full exhaust
return flow front mount
safc2 not tuned
z32
gtr34 pump
my plans where to find all leaks and get it tuned with the safc2 (for now) and save funds for injectors and a nistune
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
