1989 R32 GTST Sedan
Manual White
rego till March 2011
Engine – rb20det
180xxx kms on clock (series 2 dials) 150xxx on engine
Garrett hiflow turbo – custom made by Rotomaster
full 3inch turbo exhaust and hi flow cat – batmbl split front/dump, xforce 3inch cat convertor and tanabe medallion catback (not to loud and gives a nice note)
splitfire coilpacks
JJR return flow intercooler setup – legal piping kit
Walbro 500hp fuel pump
Apexi cam gears
Gates racing timing belt
Standard airbox with blitz panel filter
Gtr bov
MSpec dual core alloy radiator – silicon radiator hoses
1000km old extedy HD clutch
Has all the inlet piping/manifold powder coated ripple black and the engine covers powder coated red
Suspension & Braking
Largus coilovers (jap brand)
8kg fronts and 6kg rears
32 point damper adjustable
Height adjustable
(have the adjusting spanners)
Front strut brace
Alloy steering spacer
15000km old rda rotors on front
QFM A1RM pads
Hicas lock bar/hicas lines and pump completely removed
Has fairly new castor bushes
15000km old rack mount bushes
15000km old upper control arm inner and outer camber adjustable bushes
15000km old inner rack end
15000km old rack boots rubbers
15000km hicas inner rack ends
All suspension work was carried out by Centreline Suspension
Wheels
Rota D2
18 x 9 +30
235/40 goodyear eagle f1 all round – 95%
Exterior
Vertex side skirts and rear bar
Aero option front bar
TBO front lip (very rare and expensive to buy)
genuine n1 gtr bootlip
Flared front guards
Interior
retrimmed headliner in black
seats have the letherette covers in red and black
door trims retrimmed in red
el dash dials
and apexi el1 boost gauge
original series 2 floor mats in excellent condition
series 2 centre console and shifter surrounds
series 2 dials ( underneath the el dials) – shows 30000km more than whats driven
infinity 6x4’s in front doors
infinity 6” splits on parcel shelf
kenwood double din headunit
Car is in Melbourne
price is $9500 without wheels/tyres - will supply black r34 gt stockies 16" with used tyres (not roadworthy)
$10500 with wheels and tyres
call Nick on 0432 224 681
genuine inquries only and no swaps
https://www.sau.com.au/forums/topic/316220-r32-gts-t-sedan/
it will need a full inspection in adelaide cause its an 89.
if u have some stock parts layin around it should be fairly easy.
hell of a car for the price tho.
if i was after another 4dr manual and had the cash i would buy it and put it through regency myself.
well worth the coin.
https://www.sau.com.au/forums/topic/316220-r32-gts-t-sedan/#findComment-5175252
I'm sorry, you probably get asked this alot, but do you have any idea what would be required to get this approved in NSW? Definitely keen to get back into an R32 and i think i could quite easily handle driving something of this calibre...
https://www.sau.com.au/forums/topic/316220-r32-gts-t-sedan/#findComment-5197490
was just informed that some p platers may be able to drive this in Vic
From VicRoads:
From 6 July 2009, drivers issued with a probationary licence on or after 1 July 2007 may drive some lower performance turbocharged or supercharged vehicles. The definition of a lower performance turbocharged or supercharged vehicle is a vehicle with 6 cylinders or less that is;
turbocharged or supercharged with a power to weight ratio of less than 100kW per tonne;
turbocharged or supercharged with a power to weight ratio between 100kW and 125kW per tonne and that is considered to be a family type vehicle (4 seats or more) rather than a sports type vehicle. A family type vehicle is a sedan, station wagon or hatch normally used to carry families/passengers with 4 or more seats and are equipped with child restraint anchorages. A family type vehicle does not include a sports car (two door coupe)
https://www.sau.com.au/forums/topic/316220-r32-gts-t-sedan/#findComment-5206090
when i saw that post about being P Plate legal in Vic i was very interested. but there is one small problem.
New definition of probationary prohibited vehicle
(from 1 July 2007)
# has an engine with eight cylinders or more, or
# has an engine that is turbocharged or supercharged (other than a diesel powered vehicles listed in Table 1 below). There are also some lower powered turbocharged or supercharged vehicles which have been exempted and can be operated by a probationary driver who has been given an exemption by VicRoads. Refer to lower performance turbocharged or supercharged vehicles and exemptions.
# has an engine that has been modified to increase the vehicle's performance (other than a modification made by the manufacturer in the course of the manufacture of the vehicle , or
# a nominated high performance six cylinder engine. Refer to Table 2 below.
just thought i would post so that no P plater gets their hopes up only to be told they cant drive it by the first cop that pulls them up.
https://www.sau.com.au/forums/topic/316220-r32-gts-t-sedan/#findComment-5221840
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
