1989 R32 GTST Sedan
Manual White
rego till March 2011
Engine – rb20det
180xxx kms on clock (series 2 dials) 150xxx on engine
Garrett hiflow turbo – custom made by Rotomaster
full 3inch turbo exhaust and hi flow cat – batmbl split front/dump, xforce 3inch cat convertor and tanabe medallion catback (not to loud and gives a nice note)
splitfire coilpacks
JJR return flow intercooler setup – legal piping kit
Walbro 500hp fuel pump
Apexi cam gears
Gates racing timing belt
Standard airbox with blitz panel filter
Gtr bov
MSpec dual core alloy radiator – silicon radiator hoses
1000km old extedy HD clutch
Has all the inlet piping/manifold powder coated ripple black and the engine covers powder coated red
Suspension & Braking
Largus coilovers (jap brand)
8kg fronts and 6kg rears
32 point damper adjustable
Height adjustable
(have the adjusting spanners)
Front strut brace
Alloy steering spacer
15000km old rda rotors on front
QFM A1RM pads
Hicas lock bar/hicas lines and pump completely removed
Has fairly new castor bushes
15000km old rack mount bushes
15000km old upper control arm inner and outer camber adjustable bushes
15000km old inner rack end
15000km old rack boots rubbers
15000km hicas inner rack ends
All suspension work was carried out by Centreline Suspension
Wheels
Rota D2
18 x 9 +30
235/40 goodyear eagle f1 all round – 95%
Exterior
Vertex side skirts and rear bar
Aero option front bar
TBO front lip (very rare and expensive to buy)
genuine n1 gtr bootlip
Flared front guards
Interior
retrimmed headliner in black
seats have the letherette covers in red and black
door trims retrimmed in red
el dash dials
and apexi el1 boost gauge
original series 2 floor mats in excellent condition
series 2 centre console and shifter surrounds
series 2 dials ( underneath the el dials) – shows 30000km more than whats driven
infinity 6x4’s in front doors
infinity 6” splits on parcel shelf
kenwood double din headunit
Car is in Melbourne
price is $9500 without wheels/tyres - will supply black r34 gt stockies 16" with used tyres (not roadworthy)
$10500 with wheels and tyres
call Nick on 0432 224 681
genuine inquries only and no swaps
https://www.sau.com.au/forums/topic/316220-r32-gts-t-sedan/
it will need a full inspection in adelaide cause its an 89.
if u have some stock parts layin around it should be fairly easy.
hell of a car for the price tho.
if i was after another 4dr manual and had the cash i would buy it and put it through regency myself.
well worth the coin.
https://www.sau.com.au/forums/topic/316220-r32-gts-t-sedan/#findComment-5175252
I'm sorry, you probably get asked this alot, but do you have any idea what would be required to get this approved in NSW? Definitely keen to get back into an R32 and i think i could quite easily handle driving something of this calibre...
https://www.sau.com.au/forums/topic/316220-r32-gts-t-sedan/#findComment-5197490
was just informed that some p platers may be able to drive this in Vic
From VicRoads:
From 6 July 2009, drivers issued with a probationary licence on or after 1 July 2007 may drive some lower performance turbocharged or supercharged vehicles. The definition of a lower performance turbocharged or supercharged vehicle is a vehicle with 6 cylinders or less that is;
turbocharged or supercharged with a power to weight ratio of less than 100kW per tonne;
turbocharged or supercharged with a power to weight ratio between 100kW and 125kW per tonne and that is considered to be a family type vehicle (4 seats or more) rather than a sports type vehicle. A family type vehicle is a sedan, station wagon or hatch normally used to carry families/passengers with 4 or more seats and are equipped with child restraint anchorages. A family type vehicle does not include a sports car (two door coupe)
https://www.sau.com.au/forums/topic/316220-r32-gts-t-sedan/#findComment-5206090
when i saw that post about being P Plate legal in Vic i was very interested. but there is one small problem.
New definition of probationary prohibited vehicle
(from 1 July 2007)
# has an engine with eight cylinders or more, or
# has an engine that is turbocharged or supercharged (other than a diesel powered vehicles listed in Table 1 below). There are also some lower powered turbocharged or supercharged vehicles which have been exempted and can be operated by a probationary driver who has been given an exemption by VicRoads. Refer to lower performance turbocharged or supercharged vehicles and exemptions.
# has an engine that has been modified to increase the vehicle's performance (other than a modification made by the manufacturer in the course of the manufacture of the vehicle , or
# a nominated high performance six cylinder engine. Refer to Table 2 below.
just thought i would post so that no P plater gets their hopes up only to be told they cant drive it by the first cop that pulls them up.
https://www.sau.com.au/forums/topic/316220-r32-gts-t-sedan/#findComment-5221840
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
