For sale: 1983 MAZDA RX7 SII
Item Condition:NEED TO BE PAINTED RUNNING GEAR ALL BRAND NEW
Price and price conditions: $3500 WITH REG $3000 NO REG NO RWC
Extra Info: THE CAR HAS HALF PREPED FOR PAINT AND NEW PANELS HAVE BEEN FITTED ALL IT NEEDS IS A PAINT JOB AND PUT BACK TOGETHER WILL SWAP FOR S13, R32, FC RX7, or unmolested S3 rx7 LET US NO WHAT ELSE YOU GOT MUST BE NON TURBO
Pictures:BELOW MORE ON REQUEST
Contact Details:CALL JORDAN ON 0430223577 NO SMS PLZ
Delivery & Conditions of Delivery: WORK OUT WITH BUYER WILL SHIP AT BUYERS COST
ENGINE
THIS WAS JED (BUZZME) PERSONAL MOTOR BEFORE I BOUGHT IT SO ITS BUILT TO LAST IT ONLY HAS 900KMS ON IT NOT EVEN RUN IN
s3 12a tall port.
6 port housings,
large ep.
all new seals-mazda 12at apex
rx8 corner springs
mfr oil springs balanced at Xtreme rotas
xtreme finished crank
hi volume oil pump with increased oil pressure
auto counter weight.
new water pump
semi detailed
3 core radiator
davies craig thermo fan
extractors
battery in boot
new exhaust system will be supplied with sale never fitted
RUNNING GEAR
new s2 gear box
lighten flywheel
new hd clutch
new diff centre
reco tail shaft
SUSPESION
nolifane bush kit
INTERIOR
S4 RX7 front seats also have rear but dont fit
SII rx7 rear seat small rip on side cant been seen
dash board has crack but have it covered with black mat
all plastics have been painted black
custom sub rotar shaped sub box with 1200 wat boss ausdio sub
sony EXPLOD deck
sony EXPLOD 14cm speakers up front
16cm in rear
custom hand brake cover and gear boot
drift vacum gauge also fitted
near new roof lining
EXTERIOR
The hole car has had the clear coat sanded on off to ready to be sprayed in primer and painted in pulsar metalic blue
it has a euro b front bar
rear lock has been removed
new passenger door as the old was rusty
passenger door lock has been removed
all badges and rear washer have been deleted
can supply any new pannels needed got a hole parts car
the stock wheels have been painted black with chromed lip
theres pics were taken on the 13/03/2010
the car was a bit dusty
NEED THIS CAR GONE THIS MONTH MAKE A RESONBALE OFFER NO TYRE KICKER OR DREAMS PLZ
  • 1 month later...
Any pictures for the interior?
ENGINE
s3 12a tall port.
6 port housings,
large ep.
rx8 corner springs
new water pump
semi detailed
3 core radiator
extractors
battery in boot
RUNNING GEAR
new s2 gear box
lighten flywheel
new hd clutch
new diff centre
reco tail shaft
SUSPESION
nolifane bush kit
INTERIOR
sony EXPLOD deck
16cm in rear
EXTERIOR
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
