greddy guage set oil pressure oil temp exhuast temp $230
s15 s14 strut brace $40
s15 eyelids $30
s15 washer bottle $20
s15 overflow bottle $20
s15 parcel shelf $20
s15 under dash drivers side panel $20
s15 dual gauge pillar brand new $90
s15 genuine veilside rear bar painted blue $50
-4 fittings 180deg and 90deg $10ea or $40 for the lot i think theres roughly 12 fittings
-10 braided line 40cm and 30cm $20 the lot
brand new td05 oil drains x 2 $10 ea
2 inch striaght silicone hose will also throw in 4 assorted hoses aas well $30
s15 rear brake light $10
rb26 pistons x 6 and rods $60
rb26 rods x 6 $90
rb26 sump baffles $30
rb26 oil pressure sender $10
rb26 air con pump $50
5 inch canon $20
4 inch canon $20
4 inch canon with 1 metre of 3 inch pipe with 2 bolt flange $50
located on the gold coast
brad 0421511710
im sure there are more parts i will add them in the week
Keen on the braided lines, silicone connectors. Do you have any 3" to 2.5"? Any reducers around that size.
Any BOV suitable for rb25 flange? Will you post to Sydney? If so how much?
is the pressure sender in good working order and showing a good reading on the dash?
if it is then i'll take it!
hey mate not sure because i bought the engine for a conversion and i had to use the existing sender from the sr20 so never had it hooked up
  • 4 weeks later...
  • 1 month later...
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
