  • Replies 495
Posted Images
Dan,
Was funny you mentioned the five-oh on MSN. Saw none on the way home... got stopped 3 times from my place to Jason's work. It was for "random licence checks" and an RBT.
They were all sweet though, no fines, no drama. Just couldn't go more than 5mins without getting pulled up hahaha
Ha ha ha ha LOL
You should have asked if you could have kept one of the breath test pipes. Then the second time you got pulled over you could have handed that out saying "No thanks mate, already got one"
Please if you are going to attend use some common sense. We have been using this spot for close to a year now to meet up and we have had minimal trouble from police so lets try and keep it that way :D
Quoted For Emphasis
This is a friendly social get together, not an opportunity to show off your fulsik drift/skid skills. We don't like trouble with the police, I especially don't like my car being singled out because it is the same colour as the people who were being d*cks.
If you want to be a tool, go to boostlosing or Harry's
Edited by Smity42
i'll be there but I might me late. I have a meeting at 5:30 on thursday afternoon so I doubt it will finish in time for me to get on the 6 oclock bus. Won't be in brissy till about 8:30 one of you f**kers can pick me up then.
Northside cruise in?
Doable. I'm picking up the Rear Admiral from Albany Creek area, so we can meet up somewhere if you want. We may then be meeting up with someone else coming from Bulimba (not sure if they're coming yet, or where we're meeting). Might see if we can wrangle Dan into it too.
I'll be coming from a place close to work (CL Bodyworks) i'll stop in there and talk shit. Probably also have a boot load of "spare parts" from my cupboard at work. Need to make some money
I live in Albany Creek so that works, what time are you passing through?
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
