  • Replies 52
Update
Stock BOV’s $100
Stock ic piping $100
Full engine wiring loom $250
Gtr computer $100
Stock radiator with shroud $150
Front hubs $250
GTR gearbox $550 crunch in to 4th (standard)
Dash $100
Abs $50
Gtr engine crossmemeber $200
Break master cylinder $150
Peddle box $120
Bear front cut ( good for rad replacement) $300
Steering column $100
Steering rack and power steering pump $250
Lower control arm $120 pair
Fuse box $80
Starter motor $150(includes wiring)
stock air flow metres $100
Stock turbos $400
Sold stuff
IC $200 ( jenna has already flogged this)
Front struts $50 (jenna has already flogged this)
Stock steering wheel in good nick $100
Clutch lines and slave cylinder
Stock BOV’s $100
Gtr computer $100
Front hubs $250
Dash $100
Abs $50
Peddle box $120
Fuse box $80
Stock turbos $400
Sold stuff
gear knob sold
also have a os clutch that has been rebuilt for sale
on ebay
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=300421841361
starting price is the price for teh re-build kit
so you get the cluch for free
Stock BOV’s $100
Gtr computer $100
Front hubs $250
Dash $100
Abs $50
Peddle box $120
Fuse box $80
Stock turbos $400
Sold stuff
gear knob sold
stock air flow metres SOLD
