Hello SAU,
Thought I'd show you some of my photographs...i'll keep this regularly updated after every shoot I do :(
I've kept this first lot of images relatively skyline specific :)
If your on facebook; be sure to become a fan of "J & M Photography Works"
enjoy :)
...yeah a lot of images I know; but the more the merrier right? :)
Edited by darkrams69
https://www.sau.com.au/forums/topic/317385-my-photography/
Hello SAU,
Thought I'd show you some of my photographs...i'll keep this regularly updated after every shoot I do ;)
I've kept this first lot of images relatively skyline specific :/
enjoy :)
...yeah a lot of images I know; but the more the merrier right? ;)
nice pics!!!! :blink:
https://www.sau.com.au/forums/topic/317385-my-photography/#findComment-5192659
Good photos! Want to get myself a camera already and get started too, I will be sure to become a fan :)
Thanks a lot man; and thanks for become a fan :)
nice pics!!!! :cool:
Thankyou ;)
Great shots, some real nice stuff there :)
Thanks a lot :D
nice cars
Cheers :D
Got a few more pics...
https://www.sau.com.au/forums/topic/317385-my-photography/#findComment-5221244
Wow, bud your stuff is brilliant!!! =D
Thanks a lot :P Really appreciate it :P
What body/lenses are you using? I'm loving the dark/moody style, but they don't lookike HDRs?
I'm only using an EOS 450D with an 18-55 IS f/3.5-5.6, 75-300 f/4-5.6 and 50mm f/1.8 II as well as a 580EX II flash. I've also got a shopping list of lenses which i'm slowly going through haha, one by one :P
The images are HDR images, in my editing; I don't go for the unrealistic HDR images that some people produce, I like to keep an element of realism. As for the dark/moody style, that comes with my editing when creating the HDR; I deliberately go with that style to create images that are unique :)
https://www.sau.com.au/forums/topic/317385-my-photography/#findComment-5221976
Nice work boyo.. excellent angles and locations specially.
Hello SAU,
Thought I'd show you some of my photographs...i'll keep this regularly updated after every shoot I do :)
enjoy :)
...yeah a lot of images I know; but the more the merrier right? :P
https://www.sau.com.au/forums/topic/317385-my-photography/#findComment-5230948
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
