UP FOR SALE NEW 97RTT (GTRTT) BLACK PLATES WITH WHITE LETTERS AS MY CAR CHOICE WILL NOW HAVE TO GO ON HOLD THESE ARE UP FOR GRABS ASKING PRICE IS $1750 AS I KNOW THEY WILL BE HOT PROPTERY EVERY1 PICKES WHAT THEY SAY STRAIGHT AWAY. IF YOUR KEEN LET ME KNOW [email protected]
back plate is usa size so u dont need to bend it front is slimline
https://www.sau.com.au/forums/topic/317411-ppq-number-plates/
Riiiight... I'd like to see a pole on that one!
so its numbers u want hey lol well in a recent pole of 8ppl all under 30 all 8 worked it out. BUT they did all own skylines at some point so im guessing they had a bit of an advantage but if u cant see it thats cool. so we will scrap the every1 works it out line and replace it with.
so far 8 out of nine that have seen it. can make out what im tryin to say with these number plates they were bought to go on a gtr!
I expect being over 30 and having a GTR seals it for me then.
best of luck with the sale...
thanks mate lol ur never too old to have fun. keep in mind i say under 30 like its far away im closer to 30 than 28. and a GTR is still the dream
Edited by 97GTT
What in the name of blue fuck is a GTR TT? Is the TT supposed to mean twin turbo? Because if it is... that's just lame.
$1750? Try $17.50. Maybe someone called Robert Timoty Thompson born in 1997 will buy them when they turn 17 in 4 years time to put on their full hektik Hyundai Accent that they buy with their McDonalds earnings.
done mate only if u frame it. i was hoping u be willing to swap that photo
i know that i might be asking alot but im not really wanting to sell em so im asking a price they prob wont sell at if u are not intrested sweet but every GTR combo is taken and it was as close as i could get at the time and being that i will buy a gtr in time if they dont sell i will just put them on that, im not asking for approval or what u might think they are worth they are just for sale thats all
Edited by 97GTT
Potentially the longest sentence in the history of mankind...
Edited by Isola
Harsh man, too harsh.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
