no gasket.
USE this part number from repco best stuff around and you can get it in grey and black so it looks invisble.
RB26 or RB25 GTS-4 use loctite grey maxx part number 34238
RB25 or RB25 black sump use Loctite Black Maxx part number 39145
https://www.sau.com.au/forums/topic/317418-r34-sump-gasket/#findComment-5189756
Nissan use a product called 3Bond which is made in Japan. Can be obtained from Bearing Traders or some other places like Bursons. Not saying it's better than loctite but it's definitely better :0
Urethane based rather than silicon based. Plus Nissan, Toyota, Mazda and Subaru (to name a few) all use the same stuff.
Loctite works fine if you can't get the 3Bond
https://www.sau.com.au/forums/topic/317418-r34-sump-gasket/#findComment-5190087
i refuse to use that orange gear makes your work look half assed.. the whole point of nissan using it is to determine warranty jobs and if something has been apart before. The loctite numbers above are the grey and black equivs.
https://www.sau.com.au/forums/topic/317418-r34-sump-gasket/#findComment-5190305
The 3Bond is grey. I know the orange stuff you are referring to but that is used for gearboxes by Toyota. Not crankcase.
https://www.sau.com.au/forums/topic/317418-r34-sump-gasket/#findComment-5190341
The genuine NISSAN aftersales 3 bond is orange. i used to use about 10 tubes a week whilst working for NISSAN.... hence my hatred of it :)
https://www.sau.com.au/forums/topic/317418-r34-sump-gasket/#findComment-5190521
Orange and red silicone should be illegal, it makes any job you do look bad. Wurth make a good grey "silicone special" something or other, it works great, doesn't sag or fall off inside the engine and looks factory.
https://www.sau.com.au/forums/topic/317418-r34-sump-gasket/#findComment-5193665
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
