hi im looking at inter coolers on just jap and was wondering how much difference there would be between these two inter coolers when it comes to
cooling
turbo lag
ease of fitting
heat soak.
i intend on meshing the front bar to hide the intercooler from the cops interest so the shine of it doesnt matter (unless haveing mesh in front of it serverly affects the performance )
here they are
http://www.justjap.com/store/product.php?p...=339&page=1
thanks for your help
The Blitz one hands down. Larger core and overall will be better quality. All the things you listed are marginal given the two kits and nothing you would ever notice on a normal/mild setup. I'm assuming you have a stock turbo?
Also a heads up, intercooler is one word.
Edited by PM-R33
lol thanks man
ok so im better spending the extra money
also if i were to put mesh infront of the intercooler would it affect it ? iv seen cars with this so the cooler doesnt stand out ?
If you don't plan on going for over 280rwkw... IMO the cheaper one is better value and both should perform pretty much the same.
The Blitz should excel further once you push things more as generally the cores are better.
cooling
turbo lag
ease of fitting
heat soak.
here they are
Ok firstly I would always go with a well known brand name. I have personally never heard of cooling pro.
Just by looking (which is inconclusive in most cases) the blitz core appears to be of much higher construction quality and the end tanks appear to be pressed, not cast (pressed being lighter and stronger).
Also there is no photo of the inside of the cores, so you cant see how much metal/fins are inside each tube/bar. You must remember here that this can be a compromise between cooling, efficiency and flow but usually the big brands get it just right. It can also depend on what power figures your chasing.
For example, I currently have in my possesion a Hybrid GT2 core and a Greddy spec M core and the spec M core is far superior as far as fins per inch both inside and out are concerned. However the Hybrid core will do just fine for my power figure and set-up not to mention that nearly any aftermarket core will be superior to the factory side mount core. I am now using the hybrid core with great gains.
Also keep in mind that the stock R34 core is twice the size as R32, R33 and are said to be good for up to 200rwkw.
Another thing is that the cheaper brands usually still need to be modified to fit (i.e cut/trim piping) regardless of the fact that they claim it is a direct bolt on. Although having said that no direct kit will fit if, for example, the car has had an accident resulting in structure/frame work of the body being slightly or dramatically shifted.
Food for thought.
thanks for the great info mate yeah i heard the standard side mount is ment to be good but the other day i drove to the shops and back to get a pod filter and was suprized how hot the out let pipe of the inter cooler was,
but i think it comes down to my series 2 bumper for a start, that thin pushe air everywere but were its ment to go lol.
so first step ot to find a series one bar then get it painted to match , and while im fitting it i wanted a cooler to install at the same time ,
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
