Help, Anyone With R33 Heater Hoses In Or Near Gladesville Urgent!
Hi needing R33 Gtst heater hoses in from back of block to firewall urgent as I'm broken down on7 eleven Victoria Rd Drummoyne and found one of my heater hoses is busted, trying everything I can but can find another hose or stopper bung, door stop why ever can't ind anything to stop my car from pissing out water, if you can help me out asap... Umm spose I can CSM reward ya somehow but I ain't rich and I'll cover the cost of the hoses
can't afford to tow it to Fairfield and don't wana risk driving it...
so if your wrecking r33gtst or have sitting around tha I can borrow the heater hose from please
Call me on 0405626444
Thanks in advance
hey mate, which one is it exactly? the one going from the back of the motor to the thingo bolted to the firewall or from the thingo on the firewall to the passenger side leading into the heater box in the dash?
Lol@thinho too
hey sorry shouldve asked for op to close thread
by the time I posted I realized car was cool enough to locate and source the problem hose, found that original r32gtst heater hoses from coupling/joiner (brass/copper piece) at back of block to firewall in engine bay turbo had been stretced on to rb25 coupling/joiner causing weak link eventually deteriorating thought it had been replaced been replaced but Obviously wasn't and I didn't double check prior to signing off on installation. Like I really knew/saw that coming edit: previously replaced said multi coupling/joiner due to corrosion.
Anyways seeing as noone could deliver went for a walk with abit of the damaged hose and searchfor garden hose noticeably bigger than rb20 hose and then with residents permission took a lenth long enough to do a ubolt behind block and bypass the heater/firewall and return all together.
Was very happy with myself. Rebled entire cooling system at 7 eleven and even entertain led the attendand to a bit of an engine education lesson lol.
Unfortunately I was driving home low boost like max 6psi kept eye on temp&boost guage all the way home and just as I get off great western hwy turbo decides it wantS to leak boost massively and then not come on boost at all, assume damage may have been coming soon as I put 2.5bar through the other rb25 I had just replaced with the said turbo and had a little shaft play but been going strong at 1.1bar for last month or so but yeah Story of an sau'ers life really
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
